Serpent 710
Old 03-16-2004 | 03:08 AM
  #6091
InitialD's Avatar
Originally posted by cyba888
Sorry if this has been asked before but the tires that come with the kit, what shores and sizes are they?
Look in the FAQ.
clmbia45 tested the stock kit tires with his durometer and found that the shores were 40 in front and 37 in the rear.
That is why I mention to change the tires that you know the shore and the box stock setup of the 710 will not understeer terribly.
InitialD is offline
Old 03-16-2004 | 03:11 AM
  #6092
BaxterC's Avatar
dee, I thank you....
BaxterC is offline
Old 03-16-2004 | 04:10 AM
  #6093
BaxterC's Avatar
Check this out... I just ordered...
The racing Brake pads and the Stainless brake disk...
The question is not whether my car will stop... it is whether it will go...
BaxterC is offline
Old 03-16-2004 | 04:17 AM
  #6094
crashed_1's Avatar
Default Re: Re: Re: Julius' Wing?
Originally posted by InitialD
I currently want to test out these bodies but somebody is pretty slow in churning it out for me ! (j/k)
Goodness Comes To Those Who Wait
crashed_1 is offline
Old 03-16-2004 | 04:48 AM
  #6095
BaxterC's Avatar
Hey crashed... I agree with you... I offered, but I think there seems to have been a bit of a problem because he doesnt want to pay the shipping cost, tower just hit me with a $30 for $150 and rc mushroom were $100 shipping the last time, will be about the same again...
BaxterC is offline
Old 03-16-2004 | 05:05 AM
  #6096
BaxterC's Avatar
Hmmm, my config as it stands...
Serpent 710 (obviously)
Novarossi NS12S3A1
Novarossi EFRA legal in-line pipe
Racing brake pads (Serpent)
Stainless steel ventilated disk brake (Serpent)
Multiplex Profi Digital Servo (Throttle) red
KO-Propo PDS 2143 Digital servo (Steering)
KO-Propo Electronic switch
KO-Propo failsafe
KO-Propo Radio, EX11 with receiver...
and a whole load more...
I also have an HPI Honda Civic which I will play with and see how it goes... I hope she's fast like I planned... What do you all think?
BaxterC is offline
Old 03-16-2004 | 05:19 AM
  #6097
Thumbs up Clutch Question
I want to know this, the tighter the spring nut the sooner the clucth will engage ? or it is the other way around.
I am refereing to the 1.0mm adjustments that the instructions mention. If i make that distance 1.5mm will my clutch be more responsive?
currently I have to give the car alot of gas for it to move..
please help me what should i do!
Profoxcg is offline
Old 03-16-2004 | 05:32 AM
  #6098
Sow&Steady's Avatar
Default Re: Re: Re: 710 SSG
Here is 3 Racing's website !
Thanks D. Was waiting for that but had to surf back 4 pages to find it. Phew!
Sow&Steady is offline
Old 03-16-2004 | 06:08 AM
  #6099
Marcos.J's Avatar
Super Moderator
Default Re: Re: question for InitialD
You may want to try and open more holes (like 4 or 5 holes) in the shocks and give it a go with the stock 30wt oil. Else, you can follow Julius' setup of a slightly more viscous 35wt oil with 4 holes open. You'll be surprised. [/B]
with the above suggestion do i still used the yellow springs or the red springs?
Marcos.J is offline
Old 03-16-2004 | 06:14 AM
  #6100
BaxterC's Avatar
Default Re: Clutch Question
Hi Profox...
From what I remember about Centax clutches (not serpent but the principle is the same) is if you make the spring tighter, the clutch takes later\less responsive, but if you make it looser, it will be more responsive, but you ont want to make it too responsive or it will 'respond' too soon and bog the motor down which is not good at all...
BaxterC is offline
Old 03-16-2004 | 06:15 AM
  #6101
people at my track use 35wt and red...
I am using 40 and yellow....
can someone please answer my previoues posts? or am I asking stupid questions?
Profoxcg is offline
Old 03-16-2004 | 06:16 AM
  #6102
ok Thanks man !!
is the silver spring better than the one in the kit? (gold)
which one is softer?
Profoxcg is offline
Old 03-16-2004 | 06:26 AM
  #6103
BaxterC's Avatar
Sorry, I didn't see your question... You should turn it out, here is what King Dee said earlier...
I'm afraid changing to the 909518 Centax II clutch spring may make the situation worse. You could take even longer for the engine to engage the clutch ! The reason is that the 909518 Centax II clutch spring (1.8 mm diameter) is harder than the 6586 stock spring (1.7 mm diameter).
What I suggest is to loosen the Centax pre-adjusting nut (6583) until you get a decent clutch engagement without clutch slippage or without the engine revving too high. The 1.0 mm setting can be a little too much for some engines to engage the clutch.
Note that you do not have to take off the clutch bell to be able to access the Centax pre-adjusting nut. You can adjust it externally by inserting a 1.5 mm allen into one of the 2 holes on the clutch bell and catching one of the 2 grooves on the pre-adjusting nut.
Once that is done and the pre-adjusting nut held firmly externally by the 1.5 mm allen, turn the flywheel CLOCKWISE to loosen the pre-adjusting nut to get earlier engagement and ANTICLOCKWISE on the flywheel to tighten the pre-adjusting nut to get a later clutch engagement. You want to turn the flywheel CLOCKWISE.
I would suggest keeping the current spring. I think go to 0.5 mm and try from there and LET ME KNOW.... you are not the only one with the problem, when I build my car I will have to remember ALL of this...
BaxterC is offline
Old 03-16-2004 | 06:33 AM
  #6104
Marcos.J's Avatar
Super Moderator
Default driver stand
Hey InitialD,this the new drivers stand that we built at our track!
Marcos.J is offline
Old 03-16-2004 | 06:41 AM
  #6105
BaxterC's Avatar
hey, that looks sweet... Are all the tracks in the states so BIG
BaxterC is offline
