Old 03-15-2004, 03:05 AM   #5941
InitialD's Avatar
Originally posted by markp27
Let me guess, it has vanished
Jedi mind tricks at work again !
Old 03-15-2004, 03:08 AM   #5942
Just wanna share with you guys.
Yesterday was our 1st regional(state/province) TC race, I found the biggest-traction setup for rear, on my local track of course.
Using shortest upper arm UBO and LT lower arm,
4.5 camber,
+2deg Toe in,
40R / 37F tire, Trinity Shock oil 60 and 3 hole all around.
lowest DRS arm(no spacer below arm),
100% diff lock.
Stock setup in front, except
6mm (caster) in front.
-1 camber
+1 toe in
Track is quite damp, whole night heavy rain totally clean the track.
I start the practice with Romeo 2.1 shell, after 2nd tanks my car and track is start to hooked up. Bit understeer (with 100% steering DR) in the sweeper but perfect in all corner, change to Mazda 6 and Bang!! my lap times in only .5 slower than last month Lola race.
1st heat, I lower the shore 35F/37R, best lap still the same.
2nd heat, put back 37F/40R and change to 0 front toe, feels better but still same lap times.
3rd heat, same with 2nd heat but adding more FR camber 2(outside) and 1.5 inside and the car is in best condition. And lower the lap times almost .2 second than 2nd heat.
There is downside to obtain those rear setup using GQ tire and maintain 200m trackwidth
- must use Impact dogbone
- must cut the upper arm 1.5-2mm shorter, coz it hits rear hub.
But the car is able to handle my MAX to the limit.
Give it a try....
GoldFinger is offline   Reply With Quote
Old 03-15-2004, 03:08 AM   #5943
InitialD's Avatar
Originally posted by cyba888
Do you think changing to blue springs will help with the car not flipping?
Perhaps... Hey cyba, could you post your setup? Perhaps we could give better and more direct suggestions with regards to your setup.
I have personally found that softer springs work very well with the car even on moderate to high speed tracks. The car does not roll much. I guess the car is pretty light and nimble enough to use soft spring setup. My 2 cents.
Old 03-15-2004, 03:12 AM   #5944
Default Re: Diff Balls
Originally posted by crashed_1
What's the size of the 710 diff balls?...anyone?
4mm, pls let me know if find where to buy ceramic / nitride balls.
Old 03-15-2004, 03:16 AM   #5945
cyba888's Avatar
I havent received my setup board yet so the last time I setup my car was at the track using their setup station. Im using stock setup from the manual. The only thing I did was raise the DRS position to upper.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-15-2004, 03:21 AM   #5946
InitialD's Avatar
I've used this for a while now and I like it.
I guess this makes for very stable car when the car is on power.
+1 toe in
I assume that is toe out?
Are you using offset GQ tires? Perhaps the 1 mm shorter Impact dogbones on each side will work fine but I do not find any problem when I go down to 197 mm trackwidth in the rear with the current stock dogbones. The pivot ball at the upper rear arms need to go in max but without binding the edge of the arms. Camber is -3.5 and -3. Perhaps with -4.5 camber, it would be more difficult to keep the rear trackwidth to below 200 mm.
Old 03-15-2004, 03:26 AM   #5947
cyba888's Avatar
Was out with a friend the other day and guess what I saw! A nice public race track I heard it was just built so I might give it a try sometimes. The only downside is you need to bring your own table and chairs. The lights are on until midnight which is good for late night racers I guess you cant complain since its free. Its hard to tell from above but it looks like its smooth hight bite surface. Its twice as big as Silver Stone track that I usually race at. It has a huge oval track which is cool and the staights are just amazing. Definately can test out the top speed on my 710 Here is a pic of the left side of the track. Sorry for the pic quality but I only had my camera phone at the time.
Futaba 4PX
Old 03-15-2004, 03:28 AM   #5948
cyba888's Avatar
Definately a 1/8th scale dream track since its so dam big. Here is the right side of the track.
Futaba 4PX
Old 03-15-2004, 03:37 AM   #5949
Julius's Avatar
The DRS could also be part of the problem. With the arm in the upper position you'll get more steering into corners but less rear grip, which could cause the rolling problems.
Julius is offline   Reply With Quote
Old 03-15-2004, 03:42 AM   #5950
BaxterC's Avatar
Hi guys, please would you tell me the difference between ceramic bearing and normal, and also why one would want titanium screws on a cal? Have any of you actually bent or broken a screw? I am a little confused as to why one would want such strong screws...
BaxterC is offline   Reply With Quote
Old 03-15-2004, 03:45 AM   #5951
cyba888's Avatar
Thanks...ill look into that
Futaba 4PX
Old 03-15-2004, 03:46 AM   #5952
Herbie's Avatar
Default titanium
Those screws are stronger and lighter so you save some overall weight to even balance your car better to add weight where you want it the most.
Herbie is offline   Reply With Quote
Old 03-15-2004, 03:48 AM   #5953
BaxterC's Avatar
AH, I see thank you herbie... I want to order my car now....... I must wait another 13 days....
Old 03-15-2004, 03:54 AM   #5954
cyba888's Avatar
Dino... are you aware of the new track?
Futaba 4PX
Old 03-15-2004, 03:56 AM   #5955
cyba888's Avatar
Im looking into buying a second car kit. Anyone know who has the newest batch of the 710'? Besides the new 3.5mm shock tower will there be even a newer batch with the stonger bumpers and other goodies that Rene mentioned that they might fix in the future?
Futaba 4PX
