Old 03-05-2004, 03:04 PM   #5356
clmbia45's Avatar
Lightbulb
Originally posted by Rookie Solara
So you are saying you can adjust the camber by using HUDY setup system without remove or rotate anything.....? Well, that is what HUDY system suppose to be......unless you are talking about using Integy system, then I would like to know how.....
Integy: using a ball-tipped driver, slip it in under the top cross bar with the degrees marked on it. It will slide in the hole and engage the head of the pivot ball.
clmbia45 is offline   Reply With Quote
Old 03-05-2004, 03:08 PM   #5357
Trader Rating: 16 (100%+)
Very interesting.........I will give it a try. Thanks
Old 03-05-2004, 03:59 PM   #5358
I would not use ball-tipped drivers on the aluminum pivot balls, as they will damage the balls. Always try to use the straight hex driver on aluminum.
Here is a picture of the modification needed in the Hudy side ruler, and the Dremel bit used. The finish can be much better, if you don't rush, like I did.
The top hole has to be enlarged a little bit, or lift the car to access through the unmodified hole.
Fernando_M is offline   Reply With Quote
Old 03-05-2004, 04:04 PM   #5359
I don't know this is a better solution for those who cannot get in touch with the Serpent shock tower as a replacement........you can buy 2 3racings shock towers from EBAY/DINBALL.........I think for the price of 2, is a little bit less then one stock tower from Serpent (I believed they are $40 from Serpent each)....
On top of that..........you can pick the SSG version for ALL SHOW and NO GO route. I usually won't recomment 3rd market parts for Serpent, but shock towers is not something that important, also, the price of 2 to 1, it is a bargain.
What is odd is....they have only 2 shock positions....why? and what happened to the rest?
Serpent rear tower list price is $22.95 (Serpent USA)
Here is what I did, with 3mm carbon fiber. Hope you like it.
Old 03-05-2004, 07:27 PM   #5360
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally posted by InitialD
Yes, I believe the one that you're using is called molybdenum graphite grease. It is in wet grease form. I also bought that one because I was fooled into thinking that it was dry base ! I guess as they say, fools never differ.
I use "molybond" in my thrust bearings, it stayes in there under temperature and rpm.
There is also a spray on molybond available in pressure pack cans. Sprays on wet, but dries. Acts just like graphite powder without the dust and migration of lubericant. Would be good to reduce friction on pullies and belts... hint hint...
sparksy is online now   Reply With Quote
Old 03-05-2004, 07:47 PM   #5361
Pit-racer's Avatar
I told Punisher about the purple is out and orange is in.....he's a lil stuck in the past. That what he does all day is clean the car...he can't stand to see my car dirty either.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 03-05-2004, 07:48 PM   #5362
Pit-racer's Avatar
That was a fellow racer's car I posted
Old 03-05-2004, 07:49 PM   #5363
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally posted by Sow&Steady
Well ... that's a Massimo Fantini NR powerplant you've got bolted to the finest and fastest 1:10 rolling chassis on earth ... so its a really FAST car.
Like they say in F1 (and I can't wait to watch the Aussie GP this weekend), you'd need a Superlicense before you can get your paws in the driver's seat.
WEll, as u noticed already..i can't wait for the license The Road Transportation always reminded everyone to get their license beforehand before venturing to the road.
The control thing is 1st thought by my friend, rcsabah so our racers will learn the proper ways to race...this is also to prepare them for the Asean race in Kuching. In fact, most of the rules and spec were taken from the Asean race entry form...except the front windscreen ventilation hole. ours was 70mm, theirs is 50mm.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 03-05-2004, 07:50 PM   #5364
kitracer's Avatar
new option parts from 3 racing... nice
kitracer is offline   Reply With Quote
Old 03-05-2004, 07:54 PM   #5365
kitracer's Avatar
picture too big to post, help
Old 03-05-2004, 07:59 PM   #5366
jfc_tech's Avatar
try ACDSee program or the PhotoImpression 4, comes free with Canon digital camera. or better, just give us the link.
Old 03-05-2004, 08:09 PM   #5367
kitracer's Avatar
this should work
Old 03-05-2004, 08:11 PM   #5368
Like Pyramid mentioned before, the newer batch of shocktower is coming already (as a part) 4mm thick and less hole in the middle.
And thicker lower bumper plate is coming also. Not as strong as I hope but certainly way stronger than before.
We were not notice any different in upper bumper plate and/or rear lower arm.
As for rear camber adjustment, I simply use long allen key.
GoldFinger is offline   Reply With Quote
Old 03-05-2004, 08:21 PM   #5369
jfc_tech's Avatar
i don't know the part will arrive here in Sabah but for the time being, i just locked two shock towers together as attached.
Old 03-05-2004, 09:04 PM   #5370
jfc_tech's Avatar
Just wanna share here from my friend 710...all in one day of 3 heats. I pity him.
