Old 06-21-2004, 09:37 PM   #12841
InitialD's Avatar
Originally posted by BaxterC
What will you be shooting?
Charlize Theron?
Old 06-21-2004, 09:38 PM   #12842
InitialD's Avatar
Originally posted by cyba888
Here is a pic of the track that I race at, which pipe would you recommend for this track?
NovaMega TP06, Novarossi 52606/52607 or the RDLogic Turbo II inline one piece pipe. Unfortunately, they are not as durable as the Shark pipe.
Shark pipes have very good bottom end. But falls a litttle flat on the higher end. Gear for lower FDR to take advantage with the low end powerband.
Old 06-21-2004, 09:41 PM   #12843
InitialD's Avatar
Default Re: Piston broken
Originally posted by pelos
Any idea about cause of this breakage?
Too lean?
Old 06-21-2004, 09:42 PM   #12844
InitialD's Avatar
Originally posted by markp27
I was away on a bike tour for 10 days, then a couple of days at a football tournment - injured myself there and will be out-of-action for a couple of days still
Football tournament as in Euro 2004 in Portugal? Hey get well.
Old 06-21-2004, 09:45 PM   #12845
InitialD's Avatar
Originally posted by FW05R
did you guys lube the balls on the rear ball diff with grease or did you just leave them dry because the manual doesn't say to lube them at all
If you leave them dry, the diff will feel gritty after some use. If you do not grease them with good grease, it will be OK for a while but then when the grease dries up, you'll end up the same as not having grease and the diff will feel gritty after that.
When the diffs feel gritty, you need to change the newer balls if you want a smoother operating diff. Greasing the old balls will still give you a gritty diff as the balls already have flat spots on them. Anyway, the diff will still work fine, gritty or not.
Old 06-21-2004, 09:46 PM   #12846
InitialD's Avatar
Default Re: Re: you have to
Originally posted by Palmaris Europe
Funnily enough. The rear ball diff is the only thing I have never greased or oiled on the cars I have had. Never had one fail yet. Never really thought about it but I always grease/lube everything else including the pillow balls.
Don't get me wrong... You can run the diffs dry and it'll still work. But you'll get a gritty diff after a while. Flat spots in the balls will be created and you can never get rid of it even after cleaning and greasing these balls. They need to get good sticky grease when new and will stay grittyless that way. But like I mention, the diff will work fine gritty or grit free.
Old 06-21-2004, 09:48 PM   #12847
InitialD's Avatar
Originally posted by Wap
I was practice w/ 710 (Stock) and every time i brake and turn the car would spin out.
I'm assuming you're using oneway front? Perhaps something is tweaked? The first thing to do is back down the EPA on the throttle. Brake just enough that the rear wheel does not lock. Check if the chassis is straight, shocks are equal length and same rebound (especially rear), rear droop is the same and if the rear sway bar is not binding in any way. What rear droop are you running? Perhaps it's too much that causes a lot of weight transfer to the front.
A harder rear diff and a limited amount of rear droop helps to make the braking more stable.
I just ordered the box springs set and going to try some tire combos to.
Red springs and yellow stock ones are the ones used mostly. Perhaps maybe white but that is when traction is really lacking. Tires? 37, 40 and 42 shores front and rear should be about right. Depending on your setup, softer front and harder rear would help make the front and rear tire wear the same.
Old 06-21-2004, 09:49 PM   #12848
InitialD's Avatar
Originally posted by stormperson
For the diff ball, use AE stealth grease or a similar grease for ball diffs (i personally use the IRS stuff in the syringe).
The AE stealth grease is good but only for a short run. The grease wears off fast and you'll have a gritty diff. With the Mugen Super Grease, it is very sticky and sticks to the balls for what seems like eternity. A very thin layer would suffice.
Old 06-21-2004, 11:04 PM   #12849
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally posted by Marcos.S710
by the way "Happy Fathers day"
Happy belated Father's Day, Marcos. this weekend my boy will celebrate his 1 month old and i intend to get him the Savage 25 to bash around.
will get the picture posted here later on.
why not get him the 710 .... hmm, nay, too deadly for him now
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-21-2004, 11:19 PM   #12850
markp27's Avatar
Send a message via ICQ to markp27
Of course Damn, I can't stand long enough to go to the track at the moment I'll have to wait until it gets better Sitting at work with my foot up on a chair
markp27 is offline   Reply With Quote
Old 06-21-2004, 11:20 PM   #12851
markp27's Avatar
I have used both greases and D is absolutely correct - the AE stealth grease is too thin - Super Grease rules!
Old 06-21-2004, 11:20 PM   #12852
InitialD's Avatar
Can't you do that on the driver's stand?
Old 06-21-2004, 11:22 PM   #12853
markp27's Avatar
Default Winternats 2004
A sweet surprise when I got home yesterday, Ray Wood's DVD was waiting for me The DVD is worth every penny!!! Great job by Ray once more and the action is thrilling. It's amazing to watch Mike Swauger in the 1:10th - everything seemed to go wrong for him, but he kept his cool and got the job done. The 1:8th was carnage central! Fukuda looked great in the 1:8th, but Mike looked better in the 1:10th.
Go out and get your copy
Cheers, Mark.
Old 06-21-2004, 11:24 PM   #12854
markp27's Avatar
You know how tall Germans are - sitting down I can't see over the barrier of the driver's stand
Old 06-21-2004, 11:27 PM   #12855
InitialD's Avatar
Use the FORCE / RING !
Perhaps you could do some more of the breaking-in of the engine. Curious to know the performance. Crashed_1 got his already.
