Serpent 710
Originally Posted by 840918001
Hi,
The cvd's are more durable then the normal axles.
For the performens: 99% of the people out there racing won't notice the difference!
Those who do feel it, are the Pro drivers.
Bye
Bye
thnks!
I have started reading this forum from the begining, and as a rc and 710 novice I am very grateful for all the help and info on this forum.
This hobby is prohibitive to beginers in terms of budget and info and this is exactly what we need to help make this passion accesible to more and more people! Keep it coming!
Hi,
Bye
Bye
I hope this would eliminate as much freeplay as possible. I think that's where the it would make the most difference. Eliminating freeplay...
Where is everyone?
this thread have been quiet for days, really don't get used to it
btw, can anyone tell me how long does it take for the-border to ship stuff to US?
ask the border
the quite thread.. well everybody is in the sun enjoying the car i gues
have any of you guys had a chassis that was bend just by normal racing? My chassis was tweaked quite far and i didn't it something very hard or anything...
Originally Posted by _cyclops_
ask the border
try to loosen the upper deck screws and press the chassie against a hard and flat surface while tighten all the four screws down.
Hi guys!
By how many mm have you enlarged the key hole in the carbon side stiffener to apply sufficient tension to the side belt when you run the 21t side pulley?
Will this cmpromise the strenght of the carbon? Does Serpent offer a revised version of the stiffener?
I don´t have a milling machine at my disposal to enlarge the key hole in the proper way and I think a Dremel tool will not give a clean keyhole to prevent the sliding alu bit from turning when you turn the screw on the outside in order to tension the belt.
Any thoughts?
Any thoughts?
Originally Posted by fulcrum2
Hi guys!
Any thoughts?
Any thoughts?
Look here for another solution: http://www.mytsn.com/publ/publ.asp?pid=10984
I do normally use the standard side belt with the 21t pulley. The optional free run belt gives slightly more slack.
Thanks for the advice Julius!
If I understood everything correct, you found that with the modified alu bit you get enough tension to run the standard belt without opening the slot in the carbon stiffener. Right?
Thanks a lot!
Thanks a lot!
Thanks a lot!
Thanks a lot!
Hi guys,
I don't own 710, but I just built my Serpent 835 and I have a question related to what you were discussing as far as the tension on the belt goes. My problem is on contrary to yours. The side belt is very tight (I use everything stock including the pulley). It almost feels like a guitar string and I had a very hard time to get it on. I had to take off one of the pulleys and carefully press it back with the belt on. The tensioner is all the way up as there's no extra tension required on top of what it is. I have a feeling that it might be even tweaking the chassis a tiny bit (I don't have the radio plate mounted on yet) so I have to check into that.
But is it normal that when brand new the side belt is so tight?
Originally Posted by mxs
Hi guys,
Thanks Julius.
I have to admit it's suprising as this seems to be a pretty big miss by Serpent. I might try what you are suggesting but just visualizing it it doesn't make sense to me, because you are trying to get the pulleys closer. By putting the washers under the block will change somewhat its height, but will not get it any closer to the rear pulley.
The weird thing is that I browsed through mytsn forum and haven't seen anybody saying anything about side belt tension.
Thanks Julius.
Rccobra705
