Old 10-07-2005, 06:40 PM   #22456
I have the mega picco engine but i got the wrong monoblock whic is for novarossi based. It looks fit.Can that make any problems?
gokhan is offline   Reply With Quote
Old 10-08-2005, 01:37 AM   #22457
Sow&Steady's Avatar
Originally Posted by gokhan
Thanks dude
Gokhan, hope it was helpful. Did you read Rene's comments below the article? Anyway, follow the instructions and no problems. I would change the rear to a 4 hole to start with.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-08-2005, 01:38 AM   #22458
Sow&Steady's Avatar
Originally Posted by vintage
hi guys, i just got my serpent 710 2 days ago and i got the front diff.....
i need some help putting the front diff together, its a bit diffrent then the read diff that comes with the car
thanks in advance
Do the same as the rear one.
Old 10-08-2005, 01:39 AM   #22459
Sow&Steady's Avatar
Originally Posted by sokevin
anyone know where if there is front cva for the 710? part#? i have snap my thread on the dogbone-outdrive when change tire
They are the same.
Old 10-08-2005, 01:40 AM   #22460
Sow&Steady's Avatar
If it fits then no problems.
Old 10-08-2005, 02:44 AM   #22461
Yep it is ,thanks man also i found another helpful link http://www.mytsn.com/publ/publ.asp?pid=11441..
Old 10-08-2005, 05:30 AM   #22462
some parts are not the same... the front one comes with 2 clips + no plastic seal or the plastic washer that goes between the sleeve and then diff
vintage is offline   Reply With Quote
Old 10-08-2005, 10:00 AM   #22463
Pyramid's Avatar
It looks the same but when you screw them all up, the monoblock will tweak because the width between hole is different.
Pyramid is offline   Reply With Quote
Old 10-09-2005, 08:49 AM   #22464
Sow&Steady's Avatar
that's right, it is doesn't fit properly, there is going to be tweak for sure.
Old 10-09-2005, 12:09 PM   #22465
Julius's Avatar
I'm not 100% sure but I believe the difference is in the placement of the screws that blot the engine to the block. I think in the beginning when we only had the Nova monoblock we drilled out the mounting holes in the engine block slightly to make the Mega fit on the Nova block....
Might be better to try and sell the block at the track or via Ebay and get the correct part...
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 10-10-2005, 01:17 AM   #22466
Has anyone tried to mount an OS12 TZ to a monoblock? To which one?
Thanks!
fulcrum2 is offline   Reply With Quote
Old 10-10-2005, 01:40 AM   #22467
Sow&Steady's Avatar
Thanks!
I did and it doesn't work. I went back to the stock engine mounts.
Old 10-10-2005, 05:02 AM   #22468
Default dogbone pins
Does anyone know the size of the dogbone pins for a serpent 710?
My lhs sells the Hudy replacement pins but I need to know which to take.
hendrikcls is offline   Reply With Quote
Old 10-10-2005, 05:35 AM   #22469
Sow&Steady's Avatar
3 x 9.7mm
BUT take a look at this http://3hobby.net/modules.php?name=E...ontent&tid=168 and click on the link at the bottom of that page.
Old 10-10-2005, 06:27 AM   #22470
@Sow&Steady
Thanks for your advise!
By the way, Iīve just added a Mugen MRX-4 to my stable of race cars. Does anybody know where I can find a good forum (like this one for the S710) for my new speed machine? Itīs pretty quiet in the Mugen thread here...
Thanks again!
