Serpent 710
Old 06-14-2005 | 11:30 PM
  #21676
markp27's Avatar
Originally Posted by _cyclops_
wonder who comes first with the new shocks
Shocks!?!?! What new shocks?
markp27 is offline
Old 06-14-2005 | 11:33 PM
  #21677
border r/c's Avatar
Default Shocks
Serpent is testing like always with new products
yes on this moment there busy with shocks more info soon
border r/c is offline
Old 06-15-2005 | 12:55 AM
  #21678
thamjk's Avatar
Originally Posted by markp27
Oooops!!! Almost forgot.....new Alu 21T side pulley - brilliant!!! This will be perfect for the long right-hand sweeper at the nats. I find on power, then car really can now stay tight in the corner, whereas with the 22T standard pulley, the car drifts out a bit.
Here's an article from Julius about the 21T Pulley
Hi markp27, so there goes with an improvement here. Does this pulley help in small and tight tracks where a lot of braking is needed?
thamjk is offline
Old 06-15-2005 | 01:15 AM
  #21679
markp27's Avatar
It depends upon if you're using a one-way, solid or diff. The split between front and rear plays a big role in the performance of the car at the entry and exit of the corner.
I find for certain that when I run a 3mm split, the turn in isn't quite as good as when I run 2.5 or 2mm split. But less split than this starts to affect to steering at the exit of the corner (i.e. less)
Regarding braking, it doesn't really affect the braking performance at all, but may allow you to carry more speed into the corner depending upon this split you use.
Julius wrote a great article about the 21T, which explains the different possibilities: click here.
Cheers, Mark.
markp27 is offline
Old 06-15-2005 | 01:23 AM
  #21680
You don't know about the shocks?!?!?!?!
Rene and Richard are flying over curbs here at the heemstede track, it's like, 'wtf?!'.. and then he fill's the shocks again.. and like he's done in like, euuuuhm.. 5min? for ALL FOUR OF THEM!
it's a great system, and from what i've seen, i'll love them
_cyclops_ is offline
Old 06-15-2005 | 01:33 AM
  #21681
markp27's Avatar
Oh, I'm always the last to find anything out *cough*
markp27 is offline
Old 06-15-2005 | 02:18 AM
  #21682
buboy28's Avatar
bad news for me i just ordered the "OLD" aluminum shock bodies for my 710
buboy28 is offline
Old 06-15-2005 | 03:08 AM
  #21683
redsand's Avatar
dunno bout you, but i still prefer the old serpent shock from the earlier years.
btw, the old picco shocks were one of the best, they had/utilized some sort of "floating" piston.
redsand is offline
Old 06-15-2005 | 11:51 AM
  #21684
gfd2726's Avatar
Hi,
Did you order the "OLD" aluminum shock bodies online? If so, can you give me the link to them? Thanks.
gfd2726 is offline
Old 06-15-2005 | 06:18 PM
  #21685
thamjk's Avatar
Cheers, Mark.
Thanks. I got that link. Just want to find out you guys comment on this pulley before actually planing to one.
thamjk is offline
Old 06-15-2005 | 06:20 PM
  #21686
thamjk's Avatar
Hope to see them in action.
thamjk is offline
Old 06-16-2005 | 02:23 AM
  #21687
buboy28's Avatar
Arrow
Originally Posted by gfd2726
Hi,
here's the link : www.rc-mushroom.com or try www.the-border.nl
buboy28 is offline
Old 06-16-2005 | 05:19 AM
  #21688
Pyramid's Avatar
Registered User
Bro.. be sure to joint the fun,
http://www.mytsn.com/publ/publ.asp?pid=11171
Pyramid is offline
Old 06-16-2005 | 05:55 AM
  #21689
i have some parts for sale: (i list next to them what retail is and at the bottom i list what i will sell it all for)
(3) pivot pin front lower $9.95 each. total 29.85
(1) centax centrifugal shoes (clutch shoes) 4.95
(3) 57 tooth 2nd spur gear 4.95 each. total 14.85
(3) 56 tooth 2nd spur gear 4.95 each. total 14.85
(3) 55 tooth 2nd spur gear 4.95 each. total 14.85
(1) front belt 9.95
(1) rear body mount 7.95
(1) front shock piston rod set of two 7.95
(2) 23 tooth pinion gear 9.95 each. total 19.90
(3) 22 tooth pinion gear 9.95 each, total 29.85
(1) 18 tooth pinion gear 9.95
(1) 17 tooth pinion gear 9.95
(3) 16 tooth pinion gear 9.95 total 29.85
(2) front body mount 9.95 each. total 19.90
(3) shock towers 23.95 each total 71.85
(1) set of low friction belts (front middle and back) 29.95
(1) 61 tooth spur gear 4.95
(3) 60 tooth spur gear 4.95 each. total 14.85
(1) 59 tooth spur gear 4.95
(4) 21 tooth pinion gear 9.95 each. total 39.80
(2) pivot rear lower pins 9.95 each. total 19.90
(1) one way drive flange 20.95
(1) rear belt 9.95
the total of all this comes to 441.75. i will take $220 for all of it. it is all in the bags still (except one shock tower is new but out of the bag). you can email me at [email protected].
Joe Chaplow is offline
Old 06-16-2005 | 10:14 PM
  #21690
kitracer's Avatar
Nice track. wish I could come over.
Chris
kitracer is offline
