Old 06-08-2005, 11:00 AM   #21646
Regional Moderator
daniz24's Avatar
Originally Posted by Pyramid
This matters become bit worst on more annoying on EP correct Daniz24? (I'm sure you are reading this threads also )
Hey hey hey, I have to start turning on the invisible mode from now
Btw, you have a good point about some starter box design
daniz24 is offline   Reply With Quote
Old 06-08-2005, 03:50 PM   #21647
Send a message via ICQ to _cyclops_
Originally Posted by markp27
Take a look at section 4.3 in the FAQ - Julius describes a better front and rear assembly method there - including the correct sequence of tightening the screws.
Cheers, MArk.
Thanks!
Currently my chassis is being checked to see if it strait... i'll try the next time i assemble the car
_cyclops_ is offline   Reply With Quote
Old 06-08-2005, 10:44 PM   #21648
Shop Owner
Default Serpent 710 parts
We just add a lot genuine serpent parts. Also, check out the specials on OS TZ and NovaRossi RR12 series engines
toro_man is offline   Reply With Quote
Old 06-09-2005, 08:57 PM   #21649
alucard13's Avatar
I'm gone for a couple weeks and everything changes.
alucard13 is offline   Reply With Quote
Old 06-11-2005, 01:10 PM   #21650
fmolzer's Avatar
Woha !!! What happens, a guy decides to focus on F1 racing for a couple of months, and when I return to the homeland I start to see discussions about team chassis etc... Markp, give me the rundown of what is going on for new cool stuff with the 710. Basically everything from winternats and forward please?
fmolzer is offline   Reply With Quote
Old 06-11-2005, 01:33 PM   #21651
markp27's Avatar
Send a message via ICQ to markp27
Hey Fredrik - keep your eye on the ball, man!!!
Here's the new chassis:
This is a very nice tuning aid - lowers the centre of gravity and gives quite a bit of stability to the car.
New CVDs:
These are very nice, too - the drive shaft diameters are 0.5mm larger than the dog bones and the pins are also bigger, reducing the amount of slop between the drive shafts and the diff outputs.
So at the winternats, you car won't traction roll and you can't loose any more dog bones.
Other than that, you can leave your car the way it is from this years winternats.
You booked your flight yet?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 06-11-2005, 01:37 PM   #21652
markp27's Avatar
Oooops!!! Almost forgot.....new Alu 21T side pulley - brilliant!!! This will be perfect for the long right-hand sweeper at the nats. I find on power, then car really can now stay tight in the corner, whereas with the 22T standard pulley, the car drifts out a bit.
Here's an article from Julius about the 21T Pulley
Old 06-11-2005, 02:50 PM   #21653
Julius's Avatar
Two things about the new CVDs.
1 DONT'T replace the pins with the 3mm ones from serpent. They will crack the ball end of the shaft. For the adventurers: you could try to enlarge the hole so a 3mm one fits snugly.
2 Do lube the cvd side often. I take the cvd apart and grease them after each day of running. That will make sure they last a long time.
I'll try and look into the rplacement pins but the pin is slightly smaller diameter than 3mm. Could be an inches size.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 06-11-2005, 11:05 PM   #21654
markp27's Avatar
What lube/grease do you recommend for the CVD?
Old 06-12-2005, 01:37 AM   #21655
fmolzer's Avatar
Thanks for the updates. Any chance these itmes would be included if you buy a new 710 kit? I am thinking mine is getting slowly worn out and it would be time for a new kit anyway...
Old 06-12-2005, 02:49 AM   #21656
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
New CVDs:
Cheers, Mark.
Mark: where did you buy those Serpent CVD's thanks
buboy28 is offline   Reply With Quote
Old 06-12-2005, 02:50 AM   #21657
Prob. the ball bearing lube from serpent itself.... i use the stuff for nearly everything
Old 06-12-2005, 02:50 AM   #21658
Julius's Avatar
Any light greas will do. I use a stuff called Tri-Flow which is teflon based. I've had that stuff for years though so I don't know if it is still out there.
Old 06-12-2005, 02:52 AM   #21659
Julius's Avatar
Some of our drivers indeed use the bearing oil. Putting a drop on the cvd's after a few runs, and cleaning at the end of the day (or before finals).
Old 06-12-2005, 03:10 AM   #21660
stefan's Avatar
Send a message via AIM to stefan
Hi Julius,
will that new pulley fit on a Mugen MTX3 shaft (6mm ID)
stefan is offline   Reply With Quote
