Serpent 710
Heh guys, just got a used 710 and looks great. I know its yesterday's news, but got a great deal and I'm excited. Anyways, I'm going through the whole car, and I can't figure out how to set droop in the arms? I don't see any droop screws. I guess that's the problem when someone else built it.
hi guys.. Serpent 710 rocks again.. In the opening race of BUMOD Raceway in Bursa-Turkey, 3 Serpent 710's on the podium!!! Two team drivers from Serpent finished 1-2 and RCteamgo driver Ozgur finished 3rd.. Here is the picture;
Hi guys,
2 cars, a couple of different problems. Any help will be appreciated:
1. car -->
- Centax engages too early. As soon as I hit the throttle, it engages. How to avoid this? Should I tighten the clutch spring? Do I have a too large or too small clutch gap?
- The brake disc sometimes hits the flywheel. I haven't installed the 0.5 mm shim between the front bearing of the engine and the conus. If I do install that, would it solve the problem? Or is it normal for the brake disc to touch the flywheel (sometimes) when in fast motion?
2. car --> Start the car, all is ok. Hit the gas, give full throttle, no problem. Come to a corner, get off the gas, car slows down. Take the corner, hit the gas, engine revs up high, no motion on the car. It's like as if the centax is not engaging there at all. Give it a couple of tries, then it engages. How can be the problem to this one?
Any help will be appreciated. Thanks.
1. car -->
Originally Posted by Qlone
Sometimes this is caused by the clutch, but more often it is the one way bearing in the gearbox slipping. You may want to check that for proper function too (and clean it and apply just a drop of serpent's one way oil)...
The question is:
Do you mean the bearing 1320 or 1342?
Here is the gearbox assembly.
http://www.mytsn.com/products/parts.asp?prid=3525
New optional Teflon Brake Pads for your S-710, S-720 and S-960 are being shown on MyTSN.
http://www.mytsn.com/products/desc.asp?prid=4350
