Serpent 710
Old 04-13-2004 | 07:08 PM
  #8176
InitialD's Avatar
Originally posted by NitroHead
How was it??? What is the DIFFerence?
I think it's mostly that you get 4WD braking as oppose to rear 2WD braking with a oneway front. Other than that, the oneway front is generally still faster on the 710.
InitialD is offline
Old 04-13-2004 | 07:11 PM
  #8177
InitialD's Avatar
Originally posted by Profoxcg
and I was told to keep all my front and rear camber the same...
Front left and right can have different camber. So does the rear left and right. Front and rear wheels need not necessarily have the same camber.
I use -1.5 for the front left and right. In the rear, I use -3.5 on the left and -3.0 in the right. That's because the track I run on have more right hand corners and sweepers.
InitialD is offline
Old 04-13-2004 | 07:15 PM
  #8178
ok , so my understanding of camber is correct . right?
Profoxcg is offline
Old 04-13-2004 | 07:17 PM
  #8179
InitialD's Avatar
Originally posted by cyba888
I know this depends on what tracks you run on but when does your 2 speed clutch engage? I think mine engages a bit too early, at around 30% throttle. Is that too early? I just like the 2 speed to kick in right when it hits the straight but it seems to kick in too fast as well in the turns which makes it a bit difficult to drive.
The correct way is to set the 2 speed to engage about 1/3rd of the longest straight. I think that's the general rule of thumb.
If still you find the car uncomfortable in the infields that the 2nd gear still changes and makes your driving difficult, I suggest to test out using a SMALLER 1st gear spur or even using a BIGGER 1st gear pinion to compensate. You will have enough rollout to take your car in the infields in first gear. Remember that changing pinions has a bigger effect on the gearing than by changing spurs.
InitialD is offline
Old 04-13-2004 | 07:18 PM
  #8180
InitialD's Avatar
Yes.
InitialD is offline
Old 04-13-2004 | 07:25 PM
  #8181
COOL ! I AM learning I am learning !!
now I just need to drive a little better, hehe
Honestly, my driving is not that bad, its just that I need cash for tyres to try out different setups.
Profoxcg is offline
Old 04-13-2004 | 07:53 PM
  #8182
cyba888's Avatar
I think I need to make adjustments so that it doesnt engage too early. Before It would engage at halfway down the straights which in my opinion felt too late. I find it difficult to adjust the 2 speed without taking the gears out.
cyba888 is offline
Old 04-13-2004 | 08:01 PM
  #8183
Pyramid's Avatar
Registered User
Originally posted by jwf_frani
from what ive heard he is now using the kyosho evolva.
well, its good and affodable.. cannot blame him
Pyramid is offline
Old 04-13-2004 | 08:03 PM
  #8184
Pyramid's Avatar
Registered User
Hara perhaps?
If they willing to pay, I bet the first person on the list is Surikarn
Pyramid is offline
Old 04-13-2004 | 08:12 PM
  #8185
InitialD's Avatar
But isn't he already driving with Mugen / Kawahara for nitro?
InitialD is offline
Old 04-13-2004 | 08:39 PM
  #8186
InitialD's Avatar
Yes, it is difficult to access the 2 speed screws from external. I suggest taking them out. It's pretty easy. Use a flat screw and pop out the R5 C clip (keep a lot of them as spare). A quick tip... Push the C clip out downward into your pit towel on the table. That way, it will not pop out into the air when you take off the C clip !
InitialD is offline
Old 04-13-2004 | 08:41 PM
  #8187
jfc_tech's Avatar
Very nice ! In a race, you pitguy will thank you for that kind of colours. Easy to spot.
Thanks, if thats a compliment
Yea, the main purpose i paint with that color is for my pitboy to recoqnize it. Furthermore, this time, i make sure my color theme is the only one on track...i also paint my EP TB EVO III the same color. all this becoz, my pitboy ever pit the wrong car. He totally mis-watched my car which traction roll on the end of sweeping corner. He still thought my car was still running
by the way...your car's color looks awesome
Crashed_1...are ye in business for another one to paint ? How about 1 set of tires with postage/shipping included?
jfc_tech is offline
Old 04-13-2004 | 08:49 PM
  #8188
Pyramid's Avatar
Registered User
not really sure about that.. someone also said he is sponsored by kondo-japan modified engine.
Pyramid is offline
Old 04-13-2004 | 09:25 PM
  #8189
Default Gearing?
Hi everyone
iam running the standard gearing on my710 and my car was quick on the straight but seems very sluggish out of the corners i have checked my diff and my my clutch is allmost at the end of the thread! there is 0.7 gap on the clutch i am using a new mova max turbo s3 engine and out of the corners my car gets blown away buy a mugen with and jp modified in it could this be because of the gearing? tracks in this country are very small and tight. would you guys reccomend different grearing for track like these?
Brett.w is offline
Old 04-13-2004 | 09:27 PM
  #8190
crashed_1's Avatar
Do what i do, paint bodyshells for Fresh Tyres...
crashed_1 is offline
