Old 04-13-2004, 11:03 PM   #8191
InitialD's Avatar
Originally posted by crashed_1
Do what i do, paint bodyshells for Fresh Tyres...
Are you sure they will be fresh tires?
Old 04-13-2004, 11:11 PM   #8192
InitialD's Avatar
Default Re: Gearing?
Originally posted by Voodo_Magic
Hi everyone
iam running the standard gearing on my710 and my car was quick on the straight but seems very sluggish out of the corners i have checked my diff and my my clutch is allmost at the end of the thread! there is 0.7 gap on the clutch i am using a new mova max turbo s3 engine and out of the corners my car gets blown away buy a mugen with and jp modified in it could this be because of the gearing? tracks in this country are very small and tight. would you guys reccomend different grearing for track like these?
Have you done the flyweight mods?
If you have not done it at the moment, I suggest to use a smaller gap of say 0.5 mm or so.
I have done the flyweight mods. My clutch pre-tension nut is set at 1.1 mm with the stock Centax gold spring (1.7 mm diameter) and I'm currently trying the 0.7 mm clutch gap. Very hard acceleration and I need to control the throttle coming out of corners. So for smaller tracks, I suggest going to smaller gaps especially if you do not have much traction.
It could be that your engine bottom end needle (LSN) is still on the rich side which can perhaps be the problem.
Anyway, if your track is indeed small and tight, the standard 17/22 pinion and 60/56 gearing on the car will be too tall for your track. You can stick to your stock 1st gears and change just change your 2nd gears or you could just gear down to 16/21 pinion and 61/57 on the spurs.
Old 04-13-2004, 11:19 PM   #8193
Default Re: Re: Gearing?
Thanks D I have done the clutch mod and i will try your clutch settings then i will try the change of gearing, then those mugens going down!!!!
Brett.w is offline   Reply With Quote
Old 04-13-2004, 11:24 PM   #8194
Send a message via AIM to Profoxcg
if I have .5mm of pretension, it should engage sooner / lower rpms correct? or is it the other way around?
Profoxcg is offline   Reply With Quote
Old 04-13-2004, 11:34 PM   #8195
InitialD's Avatar
Yes. If you loosen your pre-tension clutch nut down to 0.5 mm, your clutch should be engaging earlier.
But anyway, I have found that with that setting I have currently on the clutch, the engine does not engage later. Still very responsive. Maybe only very slightly later than when I set to 0.4 mm clutch gap but acceleration wise with 0.7 mm clutch gap is tremendous. Very agressive clutch setting. Perhaps I need to go down to 0.6 or 0.5 mm to tone down the clutch a little or use a bigger 1st gear pinion.
Old 04-13-2004, 11:35 PM   #8196
Sow&Steady's Avatar
I don't think you need to be worried about that. You'll be the first they contact if they need any information.
I hope so. I'm desperately needing my fast charger! Not to mention my loot!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-14-2004, 12:04 AM   #8197
Pyramid's Avatar
In case not mentioned before, HSP-108250 Hudy Ultimate Setup has been revised on the openings (wider) as well as support block gauge (lightweight).
Have not yet tried mine but looks the wider openings meant for S710.
Pyramid is offline   Reply With Quote
Old 04-14-2004, 12:11 AM   #8198
InitialD's Avatar
Woow ! So much power Serpent has over Hudy !
Old 04-14-2004, 12:16 AM   #8199
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Default Finally
Hi D,
I'm finally joining the 710 family. Ordered the 710 today, should be here early next week. Looking forward putting it together.
Ron
Blue Sky is offline   Reply With Quote
Old 04-14-2004, 12:24 AM   #8200
InitialD's Avatar
Default Re: Finally
Originally posted by Blue Sky
Hi D,
Ron
Hi Ron, you're finally back to the Serpent fold after Ralph Burch leaves Serpent ! How ironic !
Hope you enjoy your stay here and the company we have. Looking forward to your inputs like in the good old non HPI forum days !
Old 04-14-2004, 01:22 AM   #8201
Unhappy Re: Re: Finally
Just read about Ralph Burch is there a Ralph Burch Snr who works for serpent as well as Ralph Burch Jr? According to the serpent usa web site Ralph Burch has left but Ralph Burch Jr won the nationals are these two different people?
Old 04-14-2004, 01:37 AM   #8202
InitialD's Avatar
Default Re: Re: Re: Finally
As far as I know, Ralph Burch Jr and Ralph Burch are the same person...
Old 04-14-2004, 01:44 AM   #8203
Default check this out!!
ok that cleared that up thanks
now check this out!
Old 04-14-2004, 01:45 AM   #8204
Default better pic?
Some of the features of this new car are:
- Front regulable one way
- Progressive suspenssion
- asimetric Suspension (different in compression and extension)
Old 04-14-2004, 01:49 AM   #8205
PSI Racing's Avatar
Default Re: better pic?
That car was shown here on the forum sometime late last year.
It looks like a nice car.
Some may not like it, but I own and run a Veteq, so I like the design.
PSI Racing is offline   Reply With Quote
