Serpent 710
Old 05-05-2006 | 01:14 AM
  #23146
Originally Posted by evo1
HI Guy's
I have a small problem with my new gear diff leaking oil on the left hand side. Not sure if i have over filled with oil or not, anyone else had a similar problem? any help would be great.
You have probably overvilled it... the silicon oil does expand when getting warm.. so don't put it full... most ppl just fill it just above the axils... also, put a thick grease on the small ruber ring and make sure it's fitted right (can be a bitch...)
_cyclops_ is offline
Old 05-05-2006 | 11:07 AM
  #23147
Originally Posted by Paolo M
Front Gear diff should be available in the next few weeks. Call your LHS to pre-order your.
What will be the advangtages over the one-way or locked one way? And what would be the recommended oil weight for treated track with med-high traction?
neltime64 is offline
Old 05-05-2006 | 03:16 PM
  #23148
DS Motorsport's Avatar
HI Guy's
Which left hand side, lookinf from the back or the front?
My diff leaked from the left hand side looking from the back.
I didn't overfilled it, but there was a small amount of play on the outdrives, i put some shims in front of the little bearing which is in the diffs.
Never had a problem since.
DS Motorsport is offline
Old 05-05-2006 | 04:33 PM
  #23149
Xyvern's Avatar
Originally Posted by lobotm
new from serpent the front geardiff due june this year :P
Gear diff
So if I install this do I need to change my driving style Currently I'm using the one way front diff.
Xyvern is offline
Old 05-06-2006 | 10:05 AM
  #23150
Yes you will need te learn that you will go a lot faster.
Old 05-15-2006 | 10:38 AM
  #23151
Xyvern's Avatar
Can you ajust the rear gear diff. ? I'm having problem setting the 710 at my local track. I've tried different tyre compound but the rear still spins out at corner.
Xyvern is offline
Old 05-15-2006 | 11:11 AM
  #23152
Gael L's Avatar
What wt oil are you running in your diff?
Gael L is offline
Old 05-15-2006 | 12:41 PM
  #23153
Xyvern's Avatar
30,000 cst. Our local track has high traction.
Xyvern is offline
Old 05-15-2006 | 08:58 PM
  #23154
Team Kamikaze's Avatar
try locking your front one way, it will be easier to drive specially if the track is loose, come on you have the ultimate optioned 710 that money can't buy
Team Kamikaze is offline
Old 06-01-2006 | 08:36 AM
  #23155
speedracer1129's Avatar
hey guys,
i found the new front gear diff set is now available:
http://rcxhobbies.com/product.php?pr...6&cat=0&page=1
speedracer1129 is offline
Old 06-01-2006 | 09:17 AM
  #23156
Just cause they are advertising it doesnt mean they actually have them yet. The guy we're buying them from (Winners Circle) is very reliable and is a serpent distributer and he is still waiting for them from serpent. If he actually has them thats great tho.
Maxx is offline
Old 06-01-2006 | 05:01 PM
  #23157
Well the border seems to have it aswell
lobotm is offline
Old 06-01-2006 | 05:05 PM
  #23158
Guys,
Diffs are in since tuesday and we are shipping to all our dealers
Paolo
Paolo M is offline
Old 06-01-2006 | 08:43 PM
  #23159
Xyvern's Avatar
Buy all your Serpent parts from : http://www.kamikazetoysandhobbies.com/home.htm
Xyvern is offline
Old 06-03-2006 | 04:58 AM
  #23160
Sow&Steady's Avatar
I posted some pics and a bit of blurp on 3hobby.net on how I installed LiPo cells in the 710.
Sow&Steady is offline
