Serpent 710
Old 06-29-2005 | 04:44 PM
  #21721
Default Turnkey 710 F/S
Perfect condition Serpent 710. Raced only twice with many 3 Racing and SERPENT hop-ups...Pulley's, Aluminum Front Shock Tower, Aluminum Rear Shock Tower, Aluminum Upper Wishbone Brackets, Aluminum Rear Diff Housing, Serpent Pro Belts, 2mm-2.5mm-3mm Rear Roll Bars, Aluminum Front Roll Bar Holders, Hudy Front Dog Bones, Aluminum Mid Shaft Bracket, Aluminum Front Body Posts. Car is sold with Battery Pack and Centax 3 clutch assy.
ONLY $350 Shipped anywhere in cont. US.
Also available MEGA ZX12 Power Pack...raced once...has 3/4 gallon 30% through it. It's a rocket and includes the 2607 inline Pipe Set.
ONLY $185
b_esser is offline
Old 06-29-2005 | 06:42 PM
  #21722
sparksy's Avatar
Originally Posted by mxs
By putting the washers under the block will change somewhat its height, but will not get it any closer to the rear pulley.
You are only putting the washers under the FRONT of the block. So yes it will raise the front of the block. In effect rotating the top of the block towards the rear.
I didbt bother with it on my 835. I soaked the belts in WD40 to soften them up a bit and then run the car in till the drive train was nice and free.
sparksy is offline
Old 06-29-2005 | 09:05 PM
  #21723
redsand's Avatar
Default Truck Body
Hi Julius,
how do they mount front body clips on a truck body ?
Pyramid..any chance you might get those truckies soon ?
redsand is offline
Old 06-30-2005 | 12:49 AM
  #21724
Julius's Avatar
Thanks Julius.
I have to admit it's suprising as this seems to be a pretty big miss by Serpent. I might try what you are suggesting but just visualizing it it doesn't make sense to me, because you are trying to get the pulleys closer. By putting the washers under the block will change somewhat its height, but will not get it any closer to the rear pulley.
The weird thing is that I browsed through mytsn forum and haven't seen anybody saying anything about side belt tension.
Because the washers are only under the front of the block you tilt it backwards a bit. That brings the pulleys closer together.
Oops, sparksky already mentioned that..
Julius is offline
Old 06-30-2005 | 12:54 AM
  #21725
Julius's Avatar
Originally Posted by redsand
Hi Julius,
The top half is a seperate part and the bottom runs all the way to the front.
Look here: http://www.mytsn.com/events/glrimage...690&imid=40939
Julius is offline
Old 06-30-2005 | 05:06 AM
  #21726
Pyramid's Avatar
Registered User
Yeah, I know... that will be really fun. In fact, this 17/JUL, we will be having a truck race with Protoform Ridez body.
If you wanted the Serpent one, we are more than happy to special order it for you @ the following (really) special prices,
SER-170027 Body Race Truck 200mm Rp. 290,000 (+-USD30).
Pyramid is offline
Old 06-30-2005 | 08:00 AM
  #21727
mxs
Thanks guys. I know what you mean now. From some reason I was thinking about the pulley side as a front. My fault.
One more question. I've heard some people just leave it tight and the belt will stretch after a while. Would that be wrong to do as it might put some extra stress on bearings and drivetrain at the begining?
Thanks again.
mxs is offline
Old 06-30-2005 | 10:10 AM
  #21728
j03s4y's Avatar
Can anyone tell me the retail price for a serpent 705? I think that's the car I am looking for to race.
j03s4y is offline
Old 06-30-2005 | 10:15 AM
  #21729
gonzoY5's Avatar
WHy wold you want to race that instead of the 710? Especially paying retail price...
gonzoY5 is offline
Old 06-30-2005 | 10:21 AM
  #21730
j03s4y's Avatar
Probably because it's cheaper and I've read theres not much difference?
A 710 goes for like $400 kit price....
j03s4y is offline
Old 06-30-2005 | 10:26 AM
  #21731
the 710 is a much better car. it is way more advanced. the 705 would not compete with the 710, mtx-3, rrr, etc.
Joe Chaplow is offline
Old 06-30-2005 | 11:21 AM
  #21732
705 is FAR (really far) from being the same as 710.....and I am not sure where did you find the $400 kit price....most of the online store (even some LHS) are around $350....
Solara is offline
Old 06-30-2005 | 12:03 PM
  #21733
rwisejr's Avatar
Sounds to me that someone is thinking more of the Impulse and the 705 which where pretty much the same car. 710 is a completely different animal .Totaly in another class compared to the other 2 !!!!
rwisejr is offline
Old 06-30-2005 | 01:47 PM
  #21734
New_Toasted's Avatar
From: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
I used to run an Impulse Pro, and when I changed to the 710 I noticed that I actullay drove better than I've thougt
New_Toasted is offline
Old 06-30-2005 | 08:15 PM
  #21735
redsand's Avatar
you've got PM.
redsand is offline
