Serpent 710
Old 12-15-2003 | 09:48 AM
  #1681
Thaasman's Avatar
Originally posted by InitialD
In certain ways, I like the 705 receive replacement better. A good balance of accessibility and protection. The Impulse PRO receiver placement was good but it was difficult to access the crystal. Not to mention certain people had problems with glitches due to the placement of the receiver.
My opinion? I don't like the placement of the receiver on the 710. Just like I do not like the placement of the receiver on the MTX-3 and V1RR EVO. My 2 cents.
You've got a point there D
Thaasman is offline
Old 12-15-2003 | 09:50 AM
  #1682
Thaasman's Avatar
Originally posted by tranced
awesome!!
now, is there any possibility you would be able to explain how this active toe-in works?
NOT AT ALL!! I can't figure it out
Thaasman is offline
Old 12-15-2003 | 09:51 AM
  #1683
InitialD's Avatar
Default Re: Re: Rx mount
Originally posted by Thaasman
It seems to be that you can only use the protector if you'r crystal and wires are all on the same side....
Strange that the Futaba receiver is different from the PCM and HRS receiver layout. The PCM (R113iP) and HRS (R203HF) receiver from the 3PK looked the same like the Sanwa receiver in terms of the crystal and plugs placement.
InitialD is offline
Old 12-15-2003 | 09:53 AM
  #1684
Thaasman's Avatar
Originally posted by Julius
You might try making a slot where the crystal fits through so you can mount it with the wires to the inside of the car?
Correct me if i'm wrong but i allways have to put the wires etc at the outside so i have to make 2 slots in the protector... And thats nearly impossible i think
Thaasman is offline
Old 12-15-2003 | 09:58 AM
  #1685
Thaasman's Avatar
Post
The only sullution for me is that i connect the wires of my reciever directly to the reciever( without the connectors)
Any comments on this one?
If you understand my explenation...
Thaasman is offline
Old 12-15-2003 | 10:17 AM
  #1686
InitialD's Avatar
I'll try...
The additional rear lower arm link that is nearer to the front of the car is like another arm located slightly higher (or lower or at a neutral position) relative to the other main rear lower arm located more towards the rear side of the car.
When the suspension compresses, this other additional rear lower arm link (located higher than the other main rear lower arm) will push the rear hub out in such a way to create less toe in. This results in more steering. The opposite happens when this other additional rear lower arm link is installed lower than the other main rear lower arm when acceleration and braking becomes more stable.
InitialD is offline
Old 12-15-2003 | 10:28 AM
  #1687
Julius's Avatar
I think you misunderstood.
Don't cut the protector, cut a slot in the lip to which you stick the receiver. Then mount it with the wires on one side of the lip and the crystal in the slot you made.
Julius is offline
Old 12-15-2003 | 10:56 AM
  #1688
Thaasman's Avatar
Post
Hmm... Pretty good idea!
I'll try that!
The only thing that i hope is that crystal does not touch the throtle servo..
Thaasman is offline
Old 12-15-2003 | 12:06 PM
  #1689
Thaasman,
You should try putting some heatshrink wrap or a bicycle intertube to hold the receiver in place on the receiver mount. That will also insolated from fuel and also you wont worried about the crystal touching your throttle servo.
PUNISHER is offline
Old 12-15-2003 | 01:06 PM
  #1690
Julius's Avatar
I'll try that!
You could use some 2-sided tape in 2 or 3 layers between the receiver and the lip. To space it away from the servo.
Julius is offline
Old 12-15-2003 | 02:34 PM
  #1691
clmbia45's Avatar
Unhappy
Thanks for the sympathy
D, there might be a day when it doesn't rain!
That'll probably be the day the dyke leaks!
clmbia45 is offline
Old 12-15-2003 | 02:52 PM
  #1692
clmbia45's Avatar
and another one
The antenna tube is not Orange!
clmbia45 is offline
Old 12-15-2003 | 03:24 PM
  #1693
... you forgot something, D Master Builder is out there.
Just PM him, he will be honoured to fix it for you.
In less then 3....
...months
(nice style by lawndoggie )
GoldFinger is offline
Old 12-15-2003 | 03:30 PM
  #1694
Default Re: Rx mount
Originally posted by fmolzer
Dang,
and I just bought 2 new futaba PCM Rx:s tfor my 710 to be, looks like they will not fit.... First person to come up with a mod that fits the Rx AND offers protection from side impacts, please post here.
..be patient , tomorow I will start building. And I have no choice, must use the R113iP.
Anyway, what throttle servo you are using ?
I use S9550 in all of my car, should be no problem if I try to mount the rcv in Rene style.
Old 12-15-2003 | 03:33 PM
  #1695
tranced's Avatar
Thanks for the pics tranced. Looks like this guy got his kit from RC Mushroom. The funny thing is what is this guy doing with the Impulse PRO battery pack in the background?
Maybe an old snake found its charm?
tranced is offline
