Old 10-01-2004, 06:14 AM   #16681
Picard's Avatar
Originally posted by InitialD
I once asked the same question and Julius did reply that the effect is not the same when putting thicker oil with more holes and using softer oil with less holes. They feel the same but they are actually not.
So did he explain the difference in the car reaction between the 2?
Picard is offline   Reply With Quote
Old 10-01-2004, 06:18 AM   #16682
Picard's Avatar
From what you say about you needing to use softer springs and hard to get the power down, it sounds like the track you run on is pretty loose. Softer tires perhaps?
Not bad D
I have tried various car setups and tire combo's with the 16T and I found softer springs are the best for this combo, but I can get faster lap times with a 17T and Harder springs.
I do run soft tyres at my track 35 speedminds on front 37's or 35's on rear depending on the grip on the day.
Old 10-01-2004, 06:29 AM   #16683
Picard's Avatar
Default Re: Re: Servo Saver Clearance
Originally posted by kreidel
How is it now hitting the bulkhead? That is not the new part so how would it change anything? I installed the new saver and it did not change the clearence on mine.
Guys
Sparksy is correct it hit on both our cars and my friends as well.
When i installed it last week I spent all day checking the car over to work out why, as sparksy has said it is nothing to do with the steering throw. For some reason the new part must sit slightly lower than the old one, but it is a very small amount to cut.
Old 10-01-2004, 06:34 AM   #16684
Picard's Avatar
I think some people will not agree with me but having lower roll center makes the front roll more and therefore not necessarily faster steering input. I find higher roll center in the front makes the car move left to right faster as the front of the car does not roll so much. No doubt lower front roll center gives more on power steering but higher front roll center makes the car's transition changes from left to right etc better.
Exactly D. This is what I have found as well and what I have been saying. I also run the high front roll centre and the car feels fantastic IMO
Old 10-01-2004, 06:36 AM   #16685
Picard's Avatar
All that is left to do is find the best dampening combo (spring and Oil). Your running Red and Yellows arn't you D?
Old 10-01-2004, 06:41 AM   #16686
Send a message via AIM to Bxclip
any body got the part number to the bulkhead to where the brakes go onto i cant find ti and need to got to my hobby shop to get it today
s733/ flash 12 3 tuned Maxy Modified/ nova 2660 w/ medium manifold/ spektrum dx3
Bxclip is offline   Reply With Quote
Old 10-01-2004, 01:04 PM   #16687
Sow&Steady's Avatar
Originally posted by Pyramid
Let"s say everyting else remain the same, you only change to softer dampening (means lower on both oil and spring rate alltogether).. this will make the car rolls more.. I think it can only react quicker and harder to drive if using softer oil but harder springs. Sure, driving style plays important role as well.
So Pyramid, this is a good point.
As a guideline, what oil do you use for which springs?
The kit comes with 30 - Yellow.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-01-2004, 01:06 PM   #16688
Sow&Steady's Avatar
Like I said, leave the red springs and put around 40WT Trinity grade oil.
Following on from my previous question, isn't the 35W Serpent oil more suited for the Red springs?
Trinity 40WT is the equivalent of which Serpent oil?
Old 10-01-2004, 01:11 PM   #16689
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
Originally posted by crashed_1
Sow, I've been running 16/61 for the past 20 tanks without stripping or modding. I can't seem to figure out what i did wrong in the past but it seems to work fine now.... Mebbe it's better meshed with a smaller 2nd gear pinion. 16/61 and 21/56 is my current combo. Oh yah, I've tried it on both blk and bronze pinions and they both work....Strange but true...
Crashed, I must say that I did have one particular set of 16/61 that went on for a while but finally the 61 stripped.
As for the smaller 2nd gear pinion, that's what I used anyway. Always 16/21 and 61/57. So I don't think that
s the issue. I think Julius expalined it best ... its got to do with the 16 teeth being on a larger than ideal/optimum diameter.
I just looked again at my new set of pinions and gears ... when the one tooth is perfectly centered on the spur, the next tooth on the pinion is actually not quite in and "rubs" a lot as it tries to engage the next tooth on the spur.
One can imagine that at high speed, AND when the pinion teeth is sharper, the tooth will bite into the spur tooth and starts the stripping sequence.
This therefore explains Pyramid's solution of meshing the two as lightly as possible but moving the engine further forward. Remember ... his mode elongates the engine mounting holes towards the front of the car.
Old 10-01-2004, 01:14 PM   #16690
Sow&Steady's Avatar
Correct ... its different because of one word .. its called "pack".
Old 10-01-2004, 01:18 PM   #16691
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New Mega's
Onkel Sow, if you have to use 16T pinion, you could use 16/60 combo which gives 7.03 FDR. 16/61 combo gives 7.15 FDR. You will note that if you want to get the same rollout as using 16/61 when using 16/60, you need to use 1 mm smaller tires all around when you're on 16/60 to achieve the same kind of acceleration.
Yes, actually I tried this. I found that for my previous set up I had to use the same shores all round and this split did not last. At some point the split disappears (rear tyres worn more than front) and I find myself losing time.
Recently though I've found the setup I like with the front on softer shore than the rear and this split lasts longer. I should therefore try your suggestion,
Making 61T larger would defeat the purpose I think since you'll have meshing problems with other 17T and 18T 1sy gear pinions.
I wasn't implying that ... I wa merely making a suggestion. Look at the previous to this one (I was answering Crashed). I've not seen what Julius means ... the 16T pinion should actually be on a smaller diameter body altogether. The current diameter is a little too large.
Old 10-01-2004, 01:20 PM   #16692
Sow&Steady's Avatar
Trinity 40wt is thinner than Serpent 30wt ! But I have a friend who runs then on his 710 with red front and blue rear spring and it works wonderful with oneway front. I think the track we run on is quite similar to yours in Surabaya.
Restecpa! That's what I thought too. Actually old Desmond once produced a chart he found somewhere and it pretty much showed that the Trinity numbers are double that of Serpent's if I remember correctly.
40Wt Trinity is closer to the equivalent of about Serpent 20-25Wt.
Old 10-01-2004, 01:24 PM   #16693
Sow&Steady's Avatar
If others can, there is no reason I could not
Depends whether the FORCE is with you or not.
Old 10-01-2004, 01:25 PM   #16694
Sow&Steady's Avatar
Originally posted by GoldFinger
Hello Darling.. how are you ?
Forget your driving style, the most important is WHEN do you race ?
Hmmm ..he/she's another one of those is he/she?
Old 10-01-2004, 01:29 PM   #16695
Sow&Steady's Avatar
OK, I'm not sure about your driving style but my local track has a fast chicane. You can see many videos of it at my site 3hobby.com.
To get a fast time on this track you definitely need to be able to transition quickly on this chicane and for me the best I've found is to use 35Wt on Red springs all round. At the moment I'm on 4 holes (stock sized holes) in front and 3 in the rear.
