Mugen MBX6
#2207
I ran the fuel line under the air filter and it doesn't have any issues with the brakes. I run the line under the filter and between the tank/guard and the front of the air snorkel with the fuel nipple on the carb facing slightly forwards towards the center diff, just enough to route the line around the front of the rubber snorkel. Don't run excess line, make it neat and you'll have no issues. The Mugen line is not as floppy as other fuel line its it hold its shape pretty well.
#2208
The retainer does lower it about 1.3mm , but it still hits it, not to mention that when you go to bleed the shock it's going to push it out farther than a 1/4'' .
The 1st pic. is one with out the retainer on the left, and the one on the right is with the retainer.
The second pic. shows how much it still hits with the retainer.
The last pic. is the shock put together with no oil , this shows how far out the diaphragm is pushing the piston and shaft.
#2209
#2210
pic
#2212
I screw in my shock end till the ball in the shock end just tightens, then back it off till its free...seems to be the perfect length after the fact. and zero issues with shocks.
#2213
this is how i route my fuel line, keeps it away from everything, sorry about the dirt, been busy, so i havent had any time to clean it up lol but no issues so far, seem alright.
#2214
Yup that's how I have mine set-up from the very beginning when I built my X6. I just use the fuel line router and bolt it to where the air filter suppose to secure to and never had problem with linkage hittin fuel line.
#2215
I'm not Mile but that is the JConcept body. I have the same one on my X6. Hope that helps. The JConcept body has more interior room so that the linkages won't rub against or hit the body like the Proline Shift body. And the nose piece is alot better looking than the Proline one.
#2217
I make sure the zip tie around the carb neck and filter is nice and secure, I don't have any issues with the air filter.
#2218
Overtime the screw will loosen a little and move the fuel line back down but just reposition the fuel line and re-tighten the screw and its good to go.
#2219
#2220
I WAS MOUNTING THE AIR FITLER IN THE screw hold but hear there was problem with it flexing and causing the filter to lean since 2 motor 1 ninja jx air filter fell off rookie move so new p4 is a rocket 10 tank s and counting mikel
