Mugen MBX6
Thanks for the info. I was really curious on just which one got better runtime. It's funny you mentioned running indoor, because next week I'm actually running an tight indoor track. So I may want to switch back to the 46 for that race. What clutch bell do you run on both, the same or do you change it up? Right now I'm running 13/44.
Ran my 6R for the first time yesterday. Was very easy to drive compared to my old D8. Only complaint is that my engine would flame out. Removed my engine and ran it in my 6T which I installed a Jammin X2 CRT fuel tank. Not one flame out. Put it back in the 6R and flame outs returned. While building the 6R I went ahead and installed a clunk and did the lid mod. Also my pressure line about 10 inches. Don't know what else I could do.
I installed a seal from an extra wheel hub bearing to the lid gasket to seal the lid opening better. Also added collars to the lid spring to ensure the lid closes.
Its kinda funny How the Car the Boots were designed for wont hold on for Very Long, Yet a Car with Even MORE drive shaft angle and they stay on until you pull it off.
Going to Foley ? If so see ya there.
hey, i ran my first mbx6r this past weekend and come in second place. i've never run a buggy before in my life. it was awlsome. patient plays a big part. i've got a lot to learn in the buggy racing world. can't wait till next race.
1/8th scale is a great class! In my opinion nitro buggy is one of the most competitive classes to run. I used to run truggy and buggy and got hectic trying to maintain both of them, while running truggy with my dad. I chose the buggy easily over truggy, I believe 1/8th buggy will be around for a long time to come! Glad you enjoyed your Mugen though!
I've been running the M2C 5 hole pistons for about 2 months now and have had very successful results with them on both the 6R and ECO. I've been running the 6R with 550 oil, 7.5 front springs and 8.0 rear springs with no rebound. On the ECO I am running 600 oil, 7.75 spring front and back with no rebound. I am wanting to try the new 1.35mm Tapered pistons from Mugen this weekend in both of my cars but I dont know where to start. What do you guys recommend running as far fluids, springs, and rebound?
Eddy
Eddy
is the rear upright for mbx6 the same with the mbx5?
Eddy
Eddy
I run the stock set up. You can look at racemugen.com for many different set ups. I believe with stock pistons I'm running 450 front and 400 rear (mugen oils). With 8.25 damper springs both front and rear. I know on the mbx6 the stock set up and many other set ups called for different springs for front and rear. I'm not sure if the length of the chasis has much to do with it, but I noticed a lot of guys were running the same damper springs both front and rear.
Eddy
