Like Tree3Likes
Mugen MBX6
Old 01-15-2009, 01:49 AM
  #2221
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
Originally Posted by Jesse
you probably not screwing in your shock end far enough.
I screw in my shock end till the ball in the shock end just tightens, then back it off till its free...seems to be the perfect length after the fact. and zero issues with shocks.
Originally Posted by *Chrominator*
The shock end is screwed in as far as it can .
Jesse it's in.
Originally Posted by ezveedub
Just to add some details on the shock/bladder. When you check your shock open like your doing now, it looks like the shaft will hit the bladder, but when assembled, it will not. As the shaft move upwards in the shock, the shaft will displace more oil, which will make the bladder rise and compress the air on the top side of the shock cap. Also, during use, the suspension will almost never travel that far up and if it does, it will be sudden. This sudden upwards movement force the bladder upwards even more, clearing the top of the shaft. Over time, I find the Mugen bladders never break, but they stretch out from all the use of compression and decompression. You'll see this when you compare the old ones with the new ones.
not to mention that when you go to bleed the shock it's going to push it out farther than a 1/4'' .
The last pic. is the shock put together with no oil , this shows how far out the diaphragm is pushing the piston and shaft.
ezveedub I thought of that but like I mentioned it seems like bleeding is going to be an issue, since I normally like to set my shock rebound at about 1/8'' . Well I will try to bleed the shock and see what happens.
Thanks everyone for the advice.
*Chrominator* is offline
Old 01-15-2009, 07:05 AM
  #2222
Trollkarln's Avatar
Originally Posted by fiveoboy01
Yes, use CA.
I just rub it around the outer periminter of the tower(and inside the hole as well too), being sure to coat the edge evenly with CA. It soaks in, cures and prevents delaminating and strengthens the tower.
I ordered a MBX6-kit a couple of days ago, and i am going to glue the front shock-tower. What kind of glue is CA? Im from Sweden and dont get all the english termes.
Thanks/ Oscar.
Trollkarln is offline
Old 01-15-2009, 07:27 AM
  #2223
Thanks/ Oscar.
Oscar The same glue you use on your tires.
Old 01-15-2009, 07:32 AM
  #2224
thuren's Avatar
Hmmmm... I always uses extra thin CA to wick into the carbon. The tire glue I use is much too thick.
thuren is offline
Old 01-15-2009, 08:31 AM
  #2225
Trader Rating: 54 (100%+)
I guess it depends on the tire glue that you use, I use thin tire glue and used the same on the shock towers.
jsmax is offline
Old 01-15-2009, 09:09 AM
  #2226
MIKESRCSTORE's Avatar
you just need thin ca glue
are you guy having problem wiht the shock tower spilting apart i run my mbx6 25 races never seen any prolem does it make i stronger 1 of my friend broke the front but i think he hit the wall hard LOL
mikel
MIKESRCSTORE is offline
Old 01-15-2009, 09:24 AM
  #2227
ezveedub's Avatar
Trader Rating: 17 (100%+)
I never did CA my shock towers. It has no splitting or issues at all.
ezveedub is offline
Old 01-15-2009, 09:46 AM
  #2228
Trollkarln's Avatar
Thank you.
Old 01-15-2009, 10:38 AM
  #2229
Default Mugen Paint Mask
Would anyone be interested in paint masks for the Mugen Logo and windows w/ borders?? This is for the stock body, but will probably be doing the Jconcepts body in the next few weeks.
I have the window masks done and should finish up the Logo this week. Masks are computer cut!
kjam is offline
Old 01-15-2009, 12:46 PM
  #2230
Trader Rating: 50 (98%+)
I am intrested. as long as the logo is the MBX-6 logo and you have the window masks for the jc body
micrors4guy is offline
Old 01-15-2009, 12:47 PM
  #2231
+1!
Jesse is offline
Old 01-15-2009, 02:58 PM
  #2232
teeforb's Avatar
Trader Rating: 94 (100%+)
hey guys, my 6 is very twitchy on the rear end. i would like to keep my deep steering in the turns, but how can i make it less twitchy on the rear end just driving it? just doing basic driving and little turns, my rear end tails a lot. i was thinking of adjusting my expo on my transmitter, but i was wondering is there i can do in terms of setup. please list like a 1, 2, 3 list with 1 being the best thing to do to solve this issue.
thx.
teeforb is offline
Old 01-15-2009, 03:17 PM
  #2233
thx.
we need more information of your current setup. I am running the kit setup with the rear hubs all the way back. in the middle hole on the hub and the top. soft rear springs with 35losi oil. My car has all the steering i could want with the rear having enought grip.
Old 01-15-2009, 05:38 PM
  #2234
dead1dave's Avatar
Which kit setup is it ? The first one ..with 5/5/2 for diffs and 450 shock oil............or the latest one that comes in the updated kits with lighter springs , lighter oil , different shock positions , 7/5/2 for diffs ..........also lighter swaybars ? Thanks
dead1dave is offline
Old 01-15-2009, 05:42 PM
  #2235
teeforb's Avatar
the older setup....
teeforb is offline
