Like Tree3Likes
Mugen MBX6
Old 11-12-2008, 07:26 AM
  #1456
Default mugen
hi guys , just checkiing. I have just finished building my mbx6 and found that the break linkage seem to hit the fuel tank especially the bottom one.
i cut the metal linkage to 60mm as suggested by the manual.
i am using ace servo horn.
any suggestions??
muaythai is offline
Old 11-12-2008, 07:42 AM
  #1457
Davidka's Avatar
Trader Rating: 86 (100%+)
Compare your servo horn to the one in the instructions. The clearance of the linkage/tank is reliant on some angle being built into the linkage setup. The links should not be exactly perpendicular to the center diff. You may need a longer horn to achieve this angle.
The MBX5r and MBX 6 clutch flywheels are exactly the same, any aftermarket clutch that worked on the old car should work with the new one.
Davidka is offline
Old 11-12-2008, 10:42 AM
  #1458
Darin Z's Avatar
Hey I have a little something to share that may be of importance to you. Last night at the races I noticed a little more than usual moisture around my carb so I started looking close at it and found the fuel tank splash guard that covers the rear of the tank toward the clutch had rubbed a hole in the rubber air filter boot. I guess from the chassis flex it had been rubbing and finally broke through. You may want to trim alittle plastic off the splash guard if its close to your air filter boot. "Of course this is all dependent on engine, filter, carb set up etc." May be nothing to some but maybe a new motor to others.
Darin Z is offline
Old 11-12-2008, 10:49 AM
  #1459
Trader Rating: 163 (100%+)
i noticed that also last weekend, i trimmed mine back around 5mm, also have to watch your clutchbell spacing so that it dosent hit the fuel tank, i seen it on my friends car
cjm1126 is offline
Old 11-12-2008, 01:28 PM
  #1460
ilmugenracer's Avatar
Originally Posted by allan42r
nice job ryan on making the show, how did you end up? we did lots a testing sun. just a couple more things to try and i'll have a indoor setup fer ya. are you still running the il champ race?
thanks bro. 6th in the A, 3rd in national points
and yeah ill be there for the champs race. what tires are working good? i look forward to the setup.
ilmugenracer is offline
Old 11-12-2008, 03:40 PM
  #1461
tony montana's Avatar
Trader Rating: 76 (100%+)
yeah the measurements in the manual for the turnbuclkes and brake and throttle linkages are a joke. Mine where way off. I had to end up cutting the spring a little for the throttle linkage
tony montana is offline
Old 11-12-2008, 04:31 PM
  #1462
Trader Rating: 18 (100%+)
I called Mugen tonight about my broken outdrive. They told me I am the
first to call with this. They would replace it only this time if i faxed
them my invoice. I know of 2 people that called Mugen about this same issue.
I bought my car at the track from a mobil hobby shop. I paid cash and
didnt get a receipt so Im SOL.
Hot Bodies sent me 4 CVD no questions asked go figure.
Anyone want an MBX6 with 2 nights on it for $400 shipped? Has M2C upper
hinge holder.
infanterene is offline
Old 11-12-2008, 04:48 PM
  #1463
Suspended
for sale mbx6 2 sets of new tires lots of extra parts 2 bodies and the tshirt it came with 460.00 firm email me [email protected]
thanks
theGeneral is offline
Old 11-12-2008, 04:51 PM
  #1464
jaylude22's Avatar
Trader Rating: 93 (99%+)
Correct me if I'm wrong, but isn't there specific section specifically intended for the sale of items you no longer want/need? It's called For Sale/Classifieds guys.
jaylude22 is offline
Old 11-12-2008, 05:10 PM
  #1465
Darin Z's Avatar
hinge holder.
Its obvious that the HB has cvd issues so Id hope they would replace them. If the problem is persistent maybe Mugen will acknowledge it easier.
Just for info, what out drive is breaking and why is it happening or what where you doing when it happened? Thanks.
Darin Z is offline
Old 11-12-2008, 05:35 PM
  #1466
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
I agree. One outdrive broken doesn't mean there is an issue. Maybe you just didn't put it together right
fiveoboy01 is offline
Old 11-12-2008, 05:41 PM
  #1467
i know I asked this before but should there be any backlash between the ring and pinion? Like I said I have the diff shimmed to make the ring and pinion tighter. Should I take the shim out and let there be just a little of back lash?
Old 11-12-2008, 07:54 PM
  #1468
I put it together right. I actually know of 2 others so it is rare but I am not the only one.
Old 11-12-2008, 08:33 PM
  #1469
on both of the cars i built i shimmed the ring gear out from the pinion. i was told to do this by mugen usa.
Old 11-12-2008, 08:41 PM
  #1470
Davidka's Avatar
As little back lash as possible but make sure they turn free. On my front diff I used no shims, on the rear the mesh was tight so I used 2 shims to move the ring gear away from the pinion.
Davidka is offline
