I'm trying to hook my buddy on a setup help guide for 12th scale. He has a 12L4 and has lots of questions. I've directed him to Mr. Payne's blog and I know there are more technical bases out there, I just am having a hard time locating them. Thanks in advance.
Here's Rich Chang's 1/12 tuning cheat sheet. Worth at least five or six times it's weight in gold...
I've got one laminated back-to-back with my Blake-issued roll-out chart. |
Jerrit- I really don't have any idea what other parts will fit the car. I have never needed to try.
Another question for you 12th scale gurus out there to ponder- Does center shock length matter on a t-bar car? On a pivot ball car this has a HUGE effect on handling by controlling the uptravel in the pod, but does it make a difference since the t-bar doesn't allow the pod to go past level.
-James |
Thanks guys, he's worried about how everyone else's cars look in the pits instead of how his rideis on the track. How do most run the smaller diameter tires front and rear without sacrificing ride height? I too have an L4 and run front without spacers and rear with CRC lowered pods and #4 down but is there something else a guy can do to prevent traction rolling and tire chunking due to thick sidewalled tires?
http://www.teamirsrc.com/caster.html Rear-Ride Height Adjusters - These improved ride height adjusters are designed to give more adjustability to the rear axle and be more stable under hard loading. There are 8 different ride height sets per package. The difference is .5mm between each height http://www.teamirsrc.com/podplates.html |
James I know Brian and I both set pod droop on our T-Bars. Even though you have the bar the pod still "wraps" under load. That wrap lifts the nose and limiting the shock can help or hinder the wrap.
You still coming up here in a couple weeks? The hotel called and we changed your room res....... :sneaky: |
Originally Posted by Fuzzy
Has anybody had any experience with the X stock motor in 12th scale? I'm looking for a range of rollouts to try this weekend and I've never used this motor before (fairly large track 90' x 50').
-Zac |
OD- what are you using to hold down the GTB's capacitor? and whats with the solder tab cover thingy? looks like all you need now is purple solder :lol:
Originally Posted by odpurple
Shoe Goo. The solder tab cover is there because it looks cool (I suppose it could protect against shorts). Working on the purple solder :lol:
servo weights
While people are weighing cars has anyone weighed the most popular servos? I don't have a scale but would be curious what the difference b/w metal and plastic gears etc is. I have a feeling that what the manufacturers publish is not 100% accurate.
| All times are GMT -7. It is currently 07:10 PM. |
