Originally Posted by Fuzzy
Has anybody had any experience with the X stock motor in 12th scale? I'm looking for a range of rollouts to try this weekend and I've never used this motor before (fairly large track 90' x 50').
Originally Posted by JamesArluck
Another question for you 12th scale gurus out there to ponder- Does center shock length matter on a t-bar car? On a pivot ball car this has a HUGE effect on handling by controlling the uptravel in the pod, but does it make a difference since the t-bar doesn't allow the pod to go past level.
-James In my experience, if i'm looking for a little more steering coming out of a corner (on power) I shorten the shock by 1/2 turn on the ball end. This takes away droop, and rear traction, giving the car more on power exit steering. I use it as a fine tuning adjustment.....but it makes a huge difference :nod: |
Hey guy's I have a simple question.
The steering block on the king-pin. Shoud one ream them out so that they float on the king pin. or leave them snug. so that they ride up and down with the king-pin. Just curious, and why. Thanks |
what do you guys think of the hara kit for the 12l4.what are the main differences between how a t bar,and pivot ball car handles????i got a 12l4 i can run both ways i never owned a 12th scale before.planning on using it on new pavement new track suface outdoors.whats the big differnce between having the servo flat or up at an angle?what 19 turn to get,was looking at checkpoint money???
The steering block on the king-pin. Shoud one ream them out so that they float on the king pin. or leave them snug. so that they ride up and down with the king-pin. Just curious, and why. Thanks If you leave it tight you can crash and have the king pin push up and preload the spring making you car handle really bad. If you ream the spindle the kingpin will always slide back to its proper orrientation. Be sure to ream the spindle after installing your axles. Knurled and threaded axles like the Parma and CRC units will swell the plastic around them. If you install the axles after reaming the kingpin bore will distort and get tight again. |
Originally Posted by EAMotorsports
Yes...It mades it debut at the Snowbirds with some good results.
EA |
-James -E |
Originally Posted by JayBee
Whaaaaaaaat!!!!!!
Originally Posted by odpurple
Yes, they are called Pro 38's and are, well, maximum diameter-38mm. They work great! As usual with Parma the wheels are really straight and the tires excellent :cool:
They are supposed to have been released already.
They aren't showing on the website yet.
I will ask about them and let you guys know.
Adrian thanks.
Just a another question or two :rolleyes: . What size reamer should one use and where can you get one? Okay 3 questions :lol: . what is the purpose of running only two pod screws on a t-bar car compared to running all three. Reason for the questions on t-bar application cars. Is that I've dropped my crc. and running a t-bar car again. |
Adrian thanks.
Just a another question or two :rolleyes: . What size reamer should one use and where can you get one? Okay 3 questions :lol: . what is the purpose of running only two pod screws on a t-bar car compared to running all three. Reason for the questions on t-bar application cars. Is that I've dropped my crc. and running a t-bar car again. -E |
hey thanks for the info. just curious when and why would you try and soften up the rear end. My guess would be to gain extra traction coming out of corner?
| All times are GMT -7. It is currently 12:24 AM. |
