Originally Posted by cyrrus
Adrian thanks.
Just a another question or two :rolleyes: . What size reamer should one use and where can you get one? Okay 3 questions :lol: . what is the purpose of running only two pod screws on a t-bar car compared to running all three. Reason for the questions on t-bar application cars. Is that I've dropped my crc. and running a t-bar car again. Like Dark said you rear will be softer. This willmake your car better over bumps, increase rear traction and make the car turn in less agressively. On asphalt you run the .063" T bad with 2 screws 99.9% of the time. On carpet you can run anything from the .063" T bad with 2 screws to an .075" with all 3 screws. Its all about the feel you want to get out of the car, how bumpy the track is and and how much traction yout track has. Don't assume that because its carpet you need to run .075" with all 3 screws. |
I had read someplace that BSR is releasing/working on a new rim for their 12th tires as well. has anybody seen/heard this as well?
Originally Posted by odpurple
Yes, they are called Pro 38's and are, well, maximum diameter-38mm. They work great! As usual with Parma the wheels are really straight and the tires excellent :cool:
Originally Posted by AdrianM
You can use a sharp 1/8" drill bit or order a 1/8" (.125) reamer from a tool supply company online like McMaster Carr.
Scottrik |
Originally Posted by InspGadgt
They aren't showing on the website yet.
16520 purple fronts 16521 magenta fronts 16532 grey rears 16534 magenta rears Paul |
Originally Posted by chicky03
They should be on our website later today or tomorrow. The compounds for the new Pro 38 wheels are:
16520 purple fronts 16521 magenta fronts 16532 grey rears 16534 magenta rears Paul Any idea if Parma will offer a "violet" compound for the front? I've taken a real liking to those for 19-T. Thanks, Scottrik |
Originally Posted by Scottrik
Paul,
Any idea if Parma will offer a "violet" compound for the front? I've taken a real liking to those for 19-T. Thanks, Scottrik Paul |
what is the purpose of running only two pod screws on a t-bar car compared to running all three?.
one of the things rarely mention that it does: it enables some vertical pod movement and dampening on a t-bar car that you don't get running all 3. the pod is mounted off of 2 fiberglass fingers like the older Delta Phazer/Spyder cars of years past. for some this helps on lo-trac, bumpy tracks, and smooths out a t-bar car. in my opinion also adds alot of forward traction. to make up for this you end up having to run softer or dual compound fronts. for people new to 12th or if your driving with drivers crashing on a straightaway infront of you for no reason....i don't recommend it. your chances of breaking a t-bar are increased over someone running all three. i have seen many new to 12th drivers go thru 2 t-bars a race trying to run the pro set-ups they see posted. especially in mod trying try to run dbl pink, magenta, cyan, violet fronts that create more steering than they can drive or handle what works at IIC, Cleveland, IFMAR Worlds, SB's, and for the Pros may not work at your local tracks. i recommend trying it both ways |
does anyone has the part number for 1/8'' reamer from McMaster Carr?
I check the website.. most of the them cost more then $30 :weird: |
I check the website.. most of the them cost more then $30 :weird: Here's the info on the Niftech reamer. $10.95 1. Straight flute with close tolerances. Full Size Image Reamer 1/8'' (.125) (#3401-.125) $10.95 Quanity: See 'em at http://www.niftech.com/ Under Catalog, then Special Tools. |
hey thanks for the info. just curious when and why would you try and soften up the rear end. My guess would be to gain extra traction coming out of corner?
I check the website.. most of the them cost more then $30 :weird: 3106A15 2975A22 2995A61 They are all between $7 and $9 -E |
thank you guys.
~Ming |
one of the things rarely mention that it does: it enables some vertical pod movement and dampening on a t-bar car that you don't get running all 3. the pod is mounted off of 2 fiberglass fingers like the older Delta Phazer/Spyder cars of years past. for some this helps on lo-trac, bumpy tracks, and smooths out a t-bar car. in my opinion also adds alot of forward traction. to make up for this you end up having to run softer or dual compound fronts. for people new to 12th or if your driving with drivers crashing on a straightaway infront of you for no reason....i don't recommend it. your chances of breaking a t-bar are increased over someone running all three. i have seen many new to 12th drivers go thru 2 t-bars a race trying to run the pro set-ups they see posted. especially in mod trying try to run dbl pink, magenta, cyan, violet fronts that create more steering than they can drive or handle what works at IIC, Cleveland, IFMAR Worlds, SB's, and for the Pros may not work at your local tracks. i recommend trying it both ways and this is why after so many years iv changed and im driving the gen x |
| All times are GMT -7. It is currently 02:23 AM. |
