Originally Posted by JamesArluck
OD-You gotta show some pictures of the sweet wire cover you made.
Originally Posted by CarlosG.
That is a fantastic job you have done with the wiring OD. Iwish mine looked like that.
My MS2.3 with LRP/Neo weighs 865g or 30.4ou with a rx pack and Speed 12. With todays bat's, you are going to have a hard time getting down to that sleek 28ou of the old days. For what it's worth, my stocker weighs 28.6ou.
Originally Posted by wyd
What different T-plates do they make for the CEFX? Any part numbers would be cool as I can start getting my parts list ready to place an order in a week or two. Anyone run the spring steel type t-plates like many of my buddies do on oval? Not sure if they are good for 1/12th or not.
i asked CEFX about it awhile back when i noticed the t-bar was smaller and the rear pivot is moved farther back than a standard AE t-bar. The C12 rear pod is much longer than an AE pod to allow for a larger range of gear selections. With the pivot moved back, this gets the geometry back correct so we have the shorter pod geometry. We have the other holes so you can use AE t-bars or the CEFX short, med, long. The kit now comes with the medium. The longer t-bar reacts slower and is easier to drive but lacks steering and a quick change of direction. It is very good on high speed, flowing tracks or ones that are really bumpy. The medium has a similar feel to driving an AE car. The short is really quick and almost twitchy to drive. It was intended for asphalt racing where sometimes you need to run a very short t-bar to generate enough steering and quick responce on a slippery surface. |
EA |
Originally Posted by SteveJa
I know that my car is WAY over weight. But I would like to know what your cars weight, mainly looking for people with brushless because that is what i have. Mine is like 880g.
Thanks |
Originally Posted by odpurple
My brushless car weighs 851 grams with 4300 and Speed 8 HD. My brushed car weighs 830 grams with KD 19t and HD :cool:
Thanks again... you have been great with the info.... |
Originally Posted by Jerrit1
Hi guys, Im new to 12th scale racing and im looking for some advice.
I own a Trinity Switchblade Spachette Edition 12th car and am wondering if I can use it or would I be screwed if i broke it. Will say an 12L4 front suspension fit on the chassis? or should I just sell it and find a car with parts readily available? Thanks. I would give Trinity a call and see if they can find any extra parts laying around. If you can get some great. If not, run it until it breaks. By the way, I have only managed to break one part this year, a lower control arm. I can honestly say that it was as hard of a hit that a stock motor can dish out. Full speed over a corner dot into a concrete wall. |
Do you guy's run the gurnie flap on the bodies?
Does it make a difference and if so what. Thanks |
Mine is 773 grams with 42's and a Komodo. with personal trans too. Its a Rev 4.5 |
What I liked at 'Birds was the 29ou min. weight they inforced. For some reason, they didn't follow Roar's 28ou limit. It must be they realise that it's going to be very difficult to get a car to that limit, so why bother. I was pleasantly surprised that I had to add a 1/4ou. to my stocker, too.
I have used the gurney flap on a 12B and on a CRC LMP. It sticks the rear down more and takes away corner entry steering (if you need that). The Speed 8 & 12 have proper balance, so it's not really needed. The 8HD is screwed to the ground even more. 773g! Did you weigh it with the body too? ;) |
Trinity Switchblade 2002 SE
Thanks for the response gubbs3.
Trinity's response to my request for parts was "Try eBay". :flaming: Will 12L4 parts fit on it? like replacing the whole front suspension to a 12L4 suspension, or will a 12L4 axle or T plates fit it? sorry if these are stupid questions, Im a complete pan car noob. Thanks, Jerrit |
Trinity's response to my request for parts was "Try eBay". :flaming: That's Trinity for you. |
Has anybody had any experience with the X stock motor in 12th scale? I'm looking for a range of rollouts to try this weekend and I've never used this motor before (fairly large track 90' x 50').
I have used the gurney flap on a 12B and on a CRC LMP. It sticks the rear down more and takes away corner entry steering (if you need that). The Speed 8 & 12 have proper balance, so it's not really needed. The 8HD is screwed to the ground even more. 773g! Did you weigh it with the body too? ;) 819 grams with a Parma Speed 8 HD. |
| All times are GMT -7. It is currently 01:02 AM. |
