So parma has a large diameter rim like the CRC High Rollers?
EA |
Originally Posted by EAMotorsports
Its just the standard spring that comes with the associated center spring. It (6lbs) or a silver (8lb) will be about all you ever need with a Tplate car. Never ran any of Josh's bodies....So I dont know. He usually runs Protoforms or Parmas...so I would stick with one of those...LOL
EA |
For super high bite tracks as the snowbirds I ran 1 set of wraps in every qual and the main. 1.62 fronts and 1.70 rears. But thats not needed for club racing. The sizes JohnnyCarey posted is where I start for club racing.
EA |
Originally Posted by wyd
What different T-plates do they make for the CEFX? Any part numbers would be cool as I can start getting my parts list ready to place an order in a week or two. Anyone run the spring steel type t-plates like many of my buddies do on oval? Not sure if they are good for 1/12th or not.
EA |
Originally Posted by Switch Blade
Question for you EA: Did you skim a layer off the top of the tyre after every run or did you just start them and let them be?
EA |
What would be a good weight of oil for the Damper tubes? 10K? Also whats the procedure to fill them or rebuild them which ever is correct?
Yes...It mades it debut at the Snowbirds with some good results.
EA |
Hopefully they will hold up to laquor thinner better then the CRC ones so I can mount my own tires. I find the old contact cement method of gluing much easier to work with then CA.
EA |
Originally Posted by Johnny Carey
1.8" and 1.85" for High Rollers. 1.71" and 1.75" for regulars.
Originally Posted by wallyedmonds
come to the metric side come come its not so bad.
the rest of the world is come come :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: I too, have come over to the metric side. My setup spreadsheet is in metric. This way, if anyone sees it, they won't be able to understand. It's "in code". |
Originally Posted by Bob-Stormer
Novak GTB 4-cell ESC pictures installed?
Anybody installed one yet in a 1/12th car? The external capacitor is half the size of the ESC... :nod: I'd love to see a few installations. (and where to mount the attached "garbage can") :lol: Thanks, -Bob |
That is a fantastic job you have done with the wiring OD. Iwish mine looked like that.
OD-You gotta show some pictures of the sweet wire cover you made.
I know that my car is WAY over weight. But I would like to know what your cars weight, mainly looking for people with brushless because that is what i have. Mine is like 880g.
Thanks |
Hi guys, Im new to 12th scale racing and im looking for some advice.
I own a Trinity Switchblade Spachette Edition 12th car and am wondering if I can use it or would I be screwed if i broke it. Will say an 12L4 front suspension fit on the chassis? or should I just sell it and find a car with parts readily available? Thanks. |
| All times are GMT -7. It is currently 05:42 PM. |
