-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
onnetz 10-13-2004 12:14 AM
Originally posted by stumper1
1/8 x 5/16
Flanged for TRC:nod:
thanks..... :p
ALBERTO 10-13-2004 05:43 AM
Originally posted by davepull
hands down the best tape to use is 3m fiberglass renforce strapping tape in is like 5/8 wide and I buy it at home depot in the paint section
thank you DAVE !!!
rayhuang 10-13-2004 07:08 AM
Hey 12L4 drivers,
Check out the for sale area here for the chassis that Paul Ciccarello, myself, Jones and RIce used for the Halloween Classic.
Do a search on rayhuang in the for sale thread and it should come right up.
Ray
Number 11 10-14-2004 01:08 AM
Re: Tire & motor questions
Originally posted by Blue Sky
Hi all, wonder if you can help with some of the following questions:
1. What size front and rear should I true the tires to for racing?
2. I usually use purple front and grey rear. What will happen if I use magenta fronts?
3. I will be running 19T motor. I have the Chameleon and Reed Quad mag. Which one would be better and what roll-out/gear ratio should I start at?
Thanks a bunch.
Blue Sky I was going to post those same questions myself tonight. I think I am going to go back up to a 19 turn for awhile until I improve in mod. The 11 turn is to powerful for me. Can anyone answer the question above we would appreciate your help. Thanks
davepull 10-14-2004 06:00 AM
cut your tires down to 1.800 front and 1.900 rear. If you put magenta fronts on it will give the car mores steering as for the motor I couldn't tell yah .
sg1 10-14-2004 06:45 AM
Blue sky...
On my BMI chassis I ran 1.75" diameter front and rear at the Holloween Classic at a high bite track... that gave me 3mm clearance front and 3 1/4mm clearance rear. I run purple fronts and grey rears, for me the magenta fronts gave a push to the car, but it was consistant, the purples heat up and get stickier as the race goes on and gives more bite. I don't know anything about the motors...
Wayne
Number 11 10-14-2004 10:10 AM
Hey Blue Sky last year I ran my chamelon between 94/31 to 33 turned my best laps geared at 94/32 and was able to run pretty close with the mod guys who ran 56 laps. Good thing I keep notes on each race or I would have never remembered this. I couldn't figure out the Reedy but now I know I need to gear up so I am going to try that out next week.
Blue Sky 10-14-2004 10:25 AM
Hey thanks all for your answer. They're all good.
11, I'm racing 1/12 this weekend in Canada and they're using 19T. That's the reason I asked. Yeah, maybe I should jog down the good info too. Thanks again.
I'll be practicing at the Rain tonight. Probably be a while before I hit the Rain again. Tried FW last Sun and was a blast with the gas sedan. Probably will do again after this wkend.
dr_hfuhuhurr 10-14-2004 12:51 PM
4 Cell Maintenence?
Ok...what are you guys doing to maintain your cells? Charge/Discharge/tray, etc? What order and what products/Settings do you use along the way.
Thanks,
Blake
scoobydo 10-14-2004 06:43 PM
1-I discharge them a night before to .9 per cell with a NovaK Smart tray to let them cool down and match drain them.
2-Race day I charge them up
3-Race them
4-I will give them a couple minutes of charge after I run them just to store them.
5-I then go back to #1 for the next time.
If you race weekly, this is a good routine for me.
If you store your batteries longer, you may have to charge and equalize them a couple of times to get the max out of them.
As far as charge rate, thats also up to you. No more than 5A I would say for 3300's.
This works for me. However, everybody is different.
cain921 10-14-2004 07:31 PM
im new at 12th scale and having some trouble with my crc bloody knife .it dont track strait it will pull left then pull right then not its wierd someone said it is my servo but it seems to work perfectly
do i need to buy a fancy digatal servo to fix it or can i try somthing else
rayhuang 10-14-2004 07:34 PM
I had the EXACT same problem last two weeks. Was getting really mad about it. Turns out-I was running a plastic gear servo for the first time-ever (JR3550) and I tightened the servo saver on too tight. Like I wold for my metal geared servos.
Try loosening it and see if your problems go away. It worked charms for me.
Ray
rayhuang 10-14-2004 07:35 PM
OH-also-the servo feels no different on the bench with it tight or just snug, but you'll know immediately on the track if it is solved.
cain921 10-14-2004 07:57 PM
thanx ill try that. never thought about the servo saver its bran-new
safaridog 10-14-2004 08:24 PM
What kind of servo do you have? I know hitec has problems centering. Also what's your front toe like.
