where would be a good place to buy receiver cells???
Do you guys know any good 1/12 scale websites with good info?
Any of you have a suggestion for a good 12th mod motor? I'mm looking to buy 9 turn, probably double or triple?
Thanks |
Originally posted by crimson eagle Any of you have a suggestion for a good 12th mod motor? I'mm looking to buy 9 turn, probably double or triple? Thanks |
Tire & motor questions
Hi all, wonder if you can help with some of the following questions:
1. What size front and rear should I true the tires to for racing? 2. I usually use purple front and grey rear. What will happen if I use magenta fronts? 3. I will be running 19T motor. I have the Chameleon and Reed Quad mag. Which one would be better and what roll-out/gear ratio should I start at? Thanks a bunch. |
Thanks Matt, I'll try that, who am I to question the the reigning region 12 12th mod champ;) I do have to admit - damn it was fast.
How you doing over there? Still clinging on to sanity? Chris. |
Originally posted by crimson eagle Thanks Matt, I'll try that, who am I to question the the reigning region 12 12th mod champ;) I do have to admit - damn it was fast. How you doing over there? Still clinging on to sanity? Chris. |
Track width problems
I am having trouble getting my car down to the correct width per roar and cleveland guidlines.
I went back to Jaco Tire from Trc tire and offset seems different. The car is too wide with jaco tires?? I am running irs lower pod plates and stock 12l3 lower plate (crc tforce chassis etc). I am running an axle that I had out of my reflex 12 big d rings. I thought it was the axle but I pulled a irs axle off the self at my local hobby shop and it was the same. Are the black trinity hubs different in offset from standard irs hubs? And I took all the shims out of the rear and still too wide. Help?? Jamie |
I know this was asked before, someplace...
But what is the Airtronics servo that alot of people use in 1/12th scale racing? I misplaced the model number. Anyone here know? |
Does anyone run a ascuri body and use a tracks transponder system? This track I have to go to doesn't allow PT's and my car is best with a ascusri. and I am not sure where is the best way to mount it.
Re: Track width problems
Originally posted by senna555 I am having trouble getting my car down to the correct width per roar and cleveland guidlines. I went back to Jaco Tire from Trc tire and offset seems different. The car is too wide with jaco tires?? I am running irs lower pod plates and stock 12l3 lower plate (crc tforce chassis etc). I am running an axle that I had out of my reflex 12 big d rings. I thought it was the axle but I pulled a irs axle off the self at my local hobby shop and it was the same. Are the black trinity hubs different in offset from standard irs hubs? And I took all the shims out of the rear and still too wide. Help?? Jamie |
Originally posted by Smalls Does anyone run a ascuri body and use a tracks transponder system? This track I have to go to doesn't allow PT's and my car is best with a ascusri. and I am not sure where is the best way to mount it. |
Stock Ratio
Guys,
What is a decent brush setup and ratio for stock(Trinity Monster) on an open 95X45 track? My current setup is shaved 4499s green springs with the Trinity Monster Stock geared 98/30 with 1.90 tires, roll out seems to be 1.83. Am I off? And how do I check the motor to get the most out of it? It only draws about 4amps at 4 volts. Thanks. |
Originally posted by CarpetRacer I know this was asked before, someplace... But what is the Airtronics servo that alot of people use in 1/12th scale racing? I misplaced the model number. Anyone here know? 9602 futaba |
| All times are GMT -7. It is currently 10:10 PM. |
