TRC Foams on a 12L4
First 12th so be gentle. Having trouble mounting TRC 12th foams on my 12L4. Front too much slop after inserting bearings and e-clips and rear supplied screws are too short. Now I know I can jimmy around each problem with shims on the front and longer hardware on the rear but I wanted to see if anyone else has run into the same problem as me. Any input is appreciated!!!!
Thanks, Kevin |
Regards dumping-try not to use full throttle be as smooth as possable,if you can stick a peice of foam on your throttle forward end point so you don't be tempted to use full power.
(I need to practse what i preach) My Q What mod motors do you find go well with 12th-im just about to start the u.k nationals & need to buy some new motors.But not sure what to buy...;) |
Re: TRC Foams on a 12L4
Originally posted by hicheef First 12th so be gentle. Having trouble mounting TRC 12th foams on my 12L4. Front too much slop after inserting bearings and e-clips and rear supplied screws are too short. Now I know I can jimmy around each problem with shims on the front and longer hardware on the rear but I wanted to see if anyone else has run into the same problem as me. Any input is appreciated!!!! Thanks, Kevin i have the same slop in the fron but did nothing to fix it :rolleyes: :rolleyes: perhaps i should :rolleyes: :rolleyes: |
Originally posted by Stevie Regards dumping-try not to use full throttle be as smooth as possable,if you can stick a peice of foam on your throttle forward end point so you don't be tempted to use full power. (I need to practse what i preach) My Q What mod motors do you find go well with 12th-im just about to start the u.k nationals & need to buy some new motors.But not sure what to buy...;) |
Originally posted by hicheef First 12th so be gentle. Having trouble mounting TRC 12th foams on my 12L4. Front too much slop after inserting bearings and e-clips and rear supplied screws are too short. Now I know I can jimmy around each problem with shims on the front and longer hardware on the rear but I wanted to see if anyone else has run into the same problem as me. Any input is appreciated!!!! Thanks, Kevin http://www2.towerhobbies.com/cgi-bin...?&I=LXD078&P=7 Not sure if this is right size, I rememer them being 1/8x1/4 but it might be 5/16. Anyway, same size as the book says, just with the flange. |
Re: Re: TRC Foams on a 12L4
Originally posted by JohnB TRC front wheels require you to use a flanged bearing. Like this: http://www2.towerhobbies.com/cgi-bin...?&I=LXD078&P=7 Not sure if this is right size, I rememer them being 1/8x1/4 but it might be 5/16. Anyway, same size as the book says, just with the flange. |
Its probably in the 290 some odd pages, but what roll out are you guys using in stock and mod?
Originally posted by Stevie My Q What mod motors do you find go well with 12th-im just about to start the u.k nationals & need to buy some new motors.But not sure what to buy...;) ALBERTO - Adjust the current limiter on your esc so it's not as punchy and you'll gain a little runtime. Also being smooth and not hitting anything in 1/12th goes a long way, every wall tap spikes your batteries(amp draw goes way up) and takes away runtime. |
Gary Fliegel - Track size?
Any good tips to get tires online, decent price and in stock?
Thanks. |
Originally posted by fatdoggy The Reedy PT is a good choice. I've run a friends pt 10x2 and it was insane. ALBERTO - Adjust the current limiter on your esc so it's not as punchy and you gain a little runtime. Also being smooth and not hitting anything in 1/12th goes a long way, every wall tap spikes your batteries(amp draw goes way up) and takes away runtime. |
CarpetRacer - www.kthobbies.com
From what I have been told, 50' x 24' It may be a bit larger.
That's a small track. Maybe around a 30mm rollout for stock and a 25mm for mod. Just guessing, I could be way off. My local track is 96'x52' and we run about a 40mm rollout for stock(MS geared a few mm higher then BS) and around a 35mm for mod(so many factors in mod though).
Receiver cells
I was just wondering if there is any interest in a shorter lighter receiver cell than the 1/4aaa's that we're running now?
The new cells would be 11mm long and have about 80 mAh. They would weigh 10-20% less than what we're running now. The cost would be about the same as what we have now. |
| All times are GMT -7. It is currently 08:10 PM. |
