htusa racing
Fast -
I forgot, Sat. will be family day as we will be going to the circus. But next Sat. (3rd) I'll be out unless we go to Phx. E |
removal
I've never had to (knock on wood) but if I did I would just cut the remaining plastic away from the axle, clean off the glue, and reuse it. At $12 a pair you don't want to just toss them...
O'D BTW if you screw them in too tight they will distort the Kingpin hole. That's why you need to glue them. |
adam
adam or ne one else who has raced on larrys track would u consider it high bite or low?
Re: removal
Originally posted by odpurple I've never had to (knock on wood) but if I did I would just cut the remaining plastic away from the axle, clean off the glue, and reuse it. At $12 a pair you don't want to just toss them... O'D BTW if you screw them in too tight they will distort the Kingpin hole. That's why you need to glue them. Now get back to work OD, so we can go racing tonight!!! |
Whats the most efficient/easy way to tape in my batteries on the 12l3?
I can't seem to get the hang of it. Took me literally 10 times (each side) til I got it satisfactory |
To tape:
Start with your 2 pieces of tape. 6-8 inches is plenty. Push the tape through the gap between the chassis and the pod. Now on the underside of the chassis, stick the tape to the bottom of the chassis. The feed about an inch of tape up through the front cell slot, which is unused. Repeat for the other side. PLace your cells into the slots. Stick the front piece of tape to the pack, then lay the back peice overthe top and underneath the chassis as far as it will go. If you find that the tape is touching the rear pod after you wrap, youre using too much tape. Repeat for other side. |
Re: adam
Originally posted by rdub202 adam or ne one else who has raced on larrys track would u consider it high bite or low? |
Re: Re: adam
Originally posted by Adam Hartzell med. to high. BTW-the GAte has been med to med high bite too:lol: But its enough to run Mod 12th and not run out of grip-so its good enough for club racing!! Ray |
Stock 1/12th current draw
Hi all,
I was wondering if a stock TC runs an avg 5 min race and draws approx 20A then what does a 4cell stock 1/12th car draw? |
About 11 to 15 amps.
question
I am running a Trinity Reflex 12 in stock class. My question is which pinion gear is decent for a P2k2 motor for 5 minute heats?
Also i am not getting enough turning on my reflex. When i go all the way right or left, the servo horn hits the 2 turnbuckles on each side. Is this normal? Also on the servo horn, which 2 holes should i put it at. There are 8 holes on my servo horn. I am using the 2 top ones. I was thinking about going to the bottom, but wasnt sure. Last question which spring should i use the silver, or copper one. I am using the silver one right now and i am liking the way it feels, should i say with it? Thanks Jon |
As far as gearing It's all going to depend on the roll out for your specific track. Talk to the track operator or the fast guy at your track and see what they recomend. Remember to privide them with your tire size and the # of theeth on your spur. I don't have a Reflex but I built one. Make sure you trim the camber links as stated on the instructions.
ya i trimmed my campber links already, but everytime i have to keep trimming them alittle more everytime. I guess i will have to ask the guys at my track in 2 months. Me on summer break :D but i brought along all my stuff.
I am getting alot of speed on the open road, and tennis track. And the motor isnt hot. But i know when i hit the track in September i know i am going to have to change things around. I just want to prepare for the changes. Another still know how i can get more steering. Also for another question, what should the mesh be like. I have movement between spur and pinion gear because thats what i hear to do. Is this correct? Is too much movement bad? Jon |
Here is a short vid my CRC 6-pack in action. Just thought I would change things up a little.
http://www.rcpics.net/view_single.php?medid=32456 4 cells, Trinity 19 turn, junk steering servo. Still has a little ways to go to be competative, but it is getting closer. |
Hi,
anyone give me some ideas for a decent cheap 12th servo? Thanks |
| All times are GMT -7. It is currently 11:14 PM. |
