Originally Posted by protc3
what motor will you be running?
chunking in the middle of the tire is not the manufactuers fault, its a combo of
1)hitting something 2)the body then hitting the tire its not that the tire wasnt glued enough |
I usually chunk the middle of fronts when I hit a track wall that is made of pipes where there is a sharp edge, it just happens.
gearing
It will be either 8 double or 9 single. unless you have any other suggestions? |
Parma Tires
I am getting back into 1/12 scale. Can someone tell me the difference between Parma rears Pink(30 shore) and Grey(also 30 shore)? And fronts, Black(35 shore) and Magenta(also 35 shore)? I am racing a CRC Bloody Knife on medim bite carpet. Thanks
Where are you getting those shore ratings?
i believe the pink compound and double pink compound have a higher natural rubber content than the greys and blacks.
i usually always run a 10x2 in mod geared at a 100/30 with a 1.75 rear tire. |
i am trying to learn more about the 12th scale tire. do you have some links or web pages that talk about what rubber familes are? i know that i am not the only one that is confused. right now where i race people are telling us to run parma or jaco purple front and parma or jaco gray rear. i had heard that before, but where do we get info like that???
thank you |
the tire you use really depends on the track conditions and which class you are running.there really is no best tire for every track.usually for stock i will start with purples up front and grey rears.for 19 turn and mod i start with 2x pink front and rear.from here i will adjust to accomodate the track conditions.
We really need someone with a durometer to test and make a chart for us.
| All times are GMT -7. It is currently 08:09 PM. |
