Tamiya TRF415
#4174
Yes they have a kit that retails for $104 for the entire car. They also have the 950's for the hubs. I have also seen ceramic diff balls too. Still trying to figure out all that they have available to drivers.
#4176
I was wondering what is the best ceramics to get for the 415. They seem to have hardness ##s that nobody talks too much about.
Speedtech, Acer, Boca.... Don't know what the better bearing is. Although with Boca you could spend double on a set.
Coop
Coop
#4177
Coop
Coop
#4178
Bearings are graded on ABEC scale, and Boca's only ones who list their rating. I'm assuming most are grade 1/lowest, or they'd be bragging about at least ABEC3 status.
Boca currently has metric bearings for this car on sale in individual pieces, ABEC7 level for $160 to get 415 setup. This does not include 2 bearings for diff, or 2 for steering. Kinda spendy, but you can't get bearing that are higher level.
#4179
#4180
#4182
Originally posted by koabich
The Acer Ceramics are ABEC5. In bearings the lower the number the better. So a 5 is higher quality than a 7. I recommend the Acer. And they are $100.00 for a COMPLETE set!
#4183
Originally posted by jeffreylin
Nope, it's the opposite. The higher the ABEC rating corresponds to higher quality bearings with tighter manufacturing tolerances.
"Lightweight ceramic balls dramatically decrease the centrifugal force placed by the balls on the rings. This, in addition to a 50% higher modulus of elasticity than conventional bearings, and Grade 5 smoothness of the balls (contrary to popular belief the lower the Grade number a ball is, the rounder and smoother it is), produce a lower coefficient of friction at the ball-raceway interface, leading to over 33% less friction in the bearing as compared to conventional bearings, and far less wear, lasting an average of ten times longer than conventional bearings. Sealed with our exclusive no contact seals for the lowest friction and best dirt resistance. These are the best and most high tech seals available."
This was a topic already discussed in another Cerimac Bearing thread. Even the gentleman that ownes RC4Less joined the discussion and said the above quote was correct. Now when talking about diff balls and diff balls only, the higher the number the better. Kinda funny, Acer offers a higher quality ball bearing while RC4Less offers a higher quality diff ball (when speaking of ceramics of course).
#4184
Here's a fact taken right off the Acer Website. Might want to read the entire thing!
Here are a few:
http://www.skatelog.com/bearings/abec.htm
http://web.skatefaq.com:81/articles/abec-hype.html
http://www.ibsco.com/tables/abec.html
http://www.dynaroll.com/catalog/pag015.htm
http://www.bocabearings.com/main1.as...Tolerances_ISO
3Likes
