Old 09-29-2004, 11:14 PM   #4021
JimmyMac's Avatar
Actually I think it'll be called the TRF415 RE (Rheinard Edition).
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-30-2004, 01:50 AM   #4022
Send a message via AIM to A-Ko
I heard it was going to be called the TRF415BE (Bling Edition), all possible parts plated in gold!
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 09-30-2004, 01:59 AM   #4023
rice's Avatar
man! 416 is coming by end of nxt year maybe 418 is release also.
lots of spending.
rice is offline   Reply With Quote
Old 09-30-2004, 05:26 AM   #4024
mashimaro's Avatar
geez, tamiya sure is introducing many top end racing cars within a very short period of time.
mashimaro is offline   Reply With Quote
Old 09-30-2004, 08:32 AM   #4025
Ballsie's Avatar
Guys, I need some help building my front diff.
I bought all the parts mentioned a few pages back.
When building the thrust bearing - how many small balls do you need and do you sandwich them between the two washers or just one washer the plastic?
Also, the Tamiya rear diff has a plastic part that contains the nut which the screw tightens, so when the screw moves, so does the nut and the plastic part. In this diff, there is no plastic, so surely the nut will just spin when you tighten the screw!
HELP !!!!!!!!!
Ballsie is offline   Reply With Quote
Old 09-30-2004, 09:01 AM   #4026
Guest
Default 416
is it true what you say the 416 is coming out by the end of next year do you know where i could get any pictures
muhuha is offline   Reply With Quote
Old 09-30-2004, 09:12 AM   #4027
V12
V12's Avatar
So you think Rheinard will win the worlds?
Like that idea!
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-30-2004, 09:15 AM   #4028
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
HELP !!!!!!!!!
if you look down inside the outdrives, one of them has a hex shaped recess in it to hold the nut...
and i think there were either 5 or 6 of the thrust balls... ill try to see if i can find the info.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-30-2004, 09:21 AM   #4029
Like that idea!
That would be cool, seems like a nice guy.
Jeffrey
Old 09-30-2004, 09:38 AM   #4030
V12
V12's Avatar
Yes thatīs true. Heīs a really nice guy. And really fast also.
Will meet him and the other guys on sunday. We have the first carpet/rubber indoor race here and itīs an international race. Itīs the CS Open.
We will see if he will dominate again.
Old 09-30-2004, 09:46 AM   #4031
koabich's Avatar
Send a message via Yahoo to koabich
I am really impressed with Marc. Good driver and seems like a nice guy. And even though I am currrenly running a Tamiya, I would like to see someone from Team Associated win the Worlds. I think they deserve one.
koabich is offline   Reply With Quote
Old 09-30-2004, 10:49 AM   #4032
Martin Crisp's Avatar
Default 415 foam/carpet setup
Hi Ng08,
I looked through my setup inventory and to my surprise I never wrote down any of my setups....
However they typically looked somthing like this.
Front:
Camber: -1.5 (sometimes -2 on side with most cornering)
Caster: 4 deg
Toe Out:0
Spring: Associated copper or purple
Shock Oil: 70w
Shock Piston:3
Shock Positionuter holes on tower and arm
Kick-Up: none - sometimes negative kickup.
Roll Center: low roll center
One way : none
Front Tire : Speedmind 35/55 multi compound
Rear:
Camber: -2
Toe In: -1.0
Spring: Associated copper or red
Shock Oil: 60w
Shock Piston:3
Shock Positionuter hole on tower and arm.
Anti-squat: none
Rear Tire : Speedmind 35
For the low roll center I ran the blocks flat on the chassis and sometimes a 2mm spacer on the inside upper link on both front and rear.
that should be a good starting point...but will need to be tuned for each track as always.
Btw - Marc is very very quick and is certainly the real deal. He could take it!
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 09-30-2004, 10:57 AM   #4033
Runin Ronin's Avatar
I agree with this statement more! Hopefully Orion gives him his own motor too, right now he'r running a Hara Edition Orion motor , He should have his own!
A TRF415RE in Fushia
Runin Ronin is offline   Reply With Quote
Old 09-30-2004, 11:09 AM   #4034
lol.so is it refine edition or reinhard edition?lol
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 09-30-2004, 12:13 PM   #4035
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default LW Suspension
anyone know how many degrees toe-in the rear upright has for the LW Suspension?
the old one was 2 degrees. not sure if the new LW ones are the same.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
