Old 08-26-2004, 11:48 AM   #3421
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally posted by John Doucakis
Thanks guys for your kind words.
Old but good car. I will compete with that at the wolrds. I might also use the EVO IV suspension.
All graphite parts are custom made. and I run Xray diffs.
That's a good looking 414!
Did you have to do anything special to run the Xray diffs, or is it an exact fit?
What graphite parts did you have made? 3mm chassis?
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 08-26-2004, 12:14 PM   #3422
ngo8's Avatar
Send a message via ICQ to ngo8
Bravo john fenete para poli kalo kali tixi sta worlds .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 08-26-2004, 01:46 PM   #3423
rcspeedo's Avatar
Originally posted by markp27
Thanks Rcsspeedo! I'll look into that. I do however have some EVO III shock shafts, are they longer?
I have been using my EVO3 Shocks as a backup for my 415 and they are the same length. The shaft that came with the 414 are still longer.
rcspeedo is offline   Reply With Quote
Old 08-26-2004, 02:24 PM   #3424
Hello EJ,
how's it goin'? Are you going to be racing anywhere this week or weekend?
Obsidian is offline   Reply With Quote
Old 08-26-2004, 04:25 PM   #3425
E.J. Evans's Avatar
Default Spool
Originally posted by Obsidian
Hello EJ,
Hey Joey, I'm thinking Speedworld.
How's the 415 treating you? I finally finished mine, should be using it this weekend.
Has anyone here found a way to stop the chattering at full steering when using a spool? I'm going to try dogbones tonight...don't know it that will help.
The only time my car didn't chatter with a spool was during the reedy. I had brand new uniys then hmmm....wonder if that had something to do with it???
Old 08-26-2004, 04:39 PM   #3426
John Doucakis's Avatar
E. J. Evans > The Xray diffs are a perfect fit. only a bit narrow but a little shimming is enough.
The graphite parts are 3mm for shock towers with some more material at some weak points.
The chassis has some more space for electronics, like the Xray chassis, and it is 2.8 mm thick.
ngo8 > Efxaristo file mou!
John Doucakis is offline   Reply With Quote
Old 08-26-2004, 09:17 PM   #3427
JimmyMac's Avatar
Okay maybe some of you guys can help me out. I didn't buy the LW suspension kit for my 415. But I have enough parts from my Evo IV to build one up for it. How do you space the arms on the 415? What shims and sizes are up front and in the rear of the arms? I'm guessing the instructions tell you what shims to use where........ Thanks..
Oh, and reading (actually looking at the pictures) one of the Japanese RC Mags... They had the 415 goin up against the Evo IV with what looks to be the same setup. Factory driver Satoshi was driving. The Evo IV produced the fastest lap of both runs thru 8 minutes. But the 415 produced a faster time overall in both runs by a few seconds over 8 minutes. Pretty cool. They actually posted his setup for the Evo IV in the mag too. I'm sure Dave has already seen this..
JMac
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-26-2004, 09:37 PM   #3428
i have the kit coming as well. Setup help would be great.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 08-26-2004, 10:06 PM   #3429
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
JMac
Sure have.. the set up works very well to but I have modifed that set up a bit because the track that I race at is very high grip
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-26-2004, 10:17 PM   #3430
Dave
Are you willing to sheare that one. I mostly run at Tamiya and the grip is usually really good there.
FT B44 - FT J82
Old 08-26-2004, 11:40 PM   #3431
jeffreylin's Avatar
R/C Tech Charter Subscriber
That's scary you've got enough parts for another set. I did a quick calculation and it's like $150+ to get all the parts needed.
Anyway here is what the instruction says:
Front--2mmx1 in front and 3mmx2 in rear
Rear--3mm+2mm in front and 3mm in rear
However, it's a bit tight in the rear and I actually use 4.5mm in rear front instead.
jeffreylin is offline   Reply With Quote
Old 08-27-2004, 02:27 AM   #3432
Ballsie's Avatar
It is very tight. I am using kit settings but considering going for less spacers.
Ballsie is offline   Reply With Quote
Old 08-27-2004, 02:36 AM   #3433
over gear's Avatar
Trader Rating: 15 (100%+)
Default Re: Spool
EJ, i have the chattering problem with spool too. i move the front a-arms all the way back, so that the spool is slight in front of the axle... when the wheel turns, the universal have a less angle and i see less chattering...... maybe a couple of run with a 6turn motor will cure that...
over gear is offline   Reply With Quote
Old 08-27-2004, 04:46 AM   #3434
yeah i had to go back to 27meg stick radio while my 40meg is in repair! the one thing i noticed is without end point adjustments the spool would chatter and bind with full lock :-( . so the one way went back in
Evo_Uk is offline   Reply With Quote
Old 08-27-2004, 04:52 AM   #3435
just wondering , anyone know if there is any chance the MI2 front diff would work with the 415?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
