Tamiya TRF415
#4201
Originally posted by Phil C
Has anyone here got a decent setup to start from for don valley on hpi b15-40'S? Im racing at the HPI junior nationals this weekend and have no idea where to start.
Cheers Phil C.
Ps. Im using the standard suspension.
Cheers Phil C.
quick check list
camber: 1.5 all round
front toe: 0deg
shock posittions: std F and R
Ride height; F 5mm, R 5.5mm
Droop: F #5, R #4 (yokomo gauge)
Springs: Yellow all round
All suspension block & and camber link spacers as Std, EXCEPT 0.7mm shims under the front/front suspension block.
You could try C/A blocks on the front too (to give some inboard toe out), I started running it like this and havent gone back since.
One thing to look out for though is the 26mm rims (as thats what I am assuming you running) can possibly rub on the front steering knuckle arm.
HiH
Ed
#4202
Originally posted by Hi-LowBrow
BTW,,,,is it possible to put the TRF sticker on my MY02Monster Jeff ??
I will be back this week--will you be racing Saturday?
#4203
Whats up guys! I'm thinking about getting a TRF415 and I was wondering what you needed for the car to run fast. I run stock asphault with rubber tires. Another questoin should i wait for the new TRF415 thats comming outi n november.? Thanks
#4204
Originally posted by ngo8
i hope this helps
i hope this helps
#4205
better entry and it smooths out the exit on turns.
#4206
#4207
I have another question, i've been hearing people changing something like the bulk heads with the evo4 or something like that. Or getting new parts for the transmission, is there a reason why? And the New TRF415, any guess's on cost or will it be the same? And it comes with new suspension, shock towers, anything else? Thanks
#4208
Speedtech R/C (as well as others) sell it. This is the link to it:
http://64.70.208.72/speedtechrc/143.html
Tamiya also released a "Finned Motor mount/bulkhead, p/n 49342" for the 415.
Hope this helps.
Terence
Cole Bros. Racing
#4209
Just got the aluminum rear hubs for the LW suspension from Square in 1.5-degree. Looks really cool and pretty light.
#4210
Hum, pic does not work, oh-well.
#4211
new/old suspension:
at the cs-race the marcs used the old suspension, i used the new one. in the early training runs my car was 2/10 faster than the others. but when traction increased my car wasn't that fast anymore compared to jonas, benni gröscheloder the marcs.i think the new suspension works hreat on tarmac and on low traction-tracks.
last sunday ronald völker (tamiya wc) and me practised on a quite small/new high traction track. at the beginning i was again much more faster with the new susp. but in the evening when traction wasreally high ronald was 2/10 faster.
again the same effect....
btw,perhaps some more non-german-drivers will participate at the cs-race next year.
#4212
another one...
#4213
Originally posted by Leini
new/old suspension:
new/old suspension:
May I have your asphalt setup for a medium grip track (tight track), with the evo4 suspensions.
How much droop do you put on the rear (generally). I ask you this because when I put 4 on the rear there is a gap between the spring and the collar. I have to put 7 onthe rear in order to remove this gap, is it normal?(this is for the regular suspensions).
#4214
So no one knows when the refined TRF415 kit is coming out? So the LW kit for the TRF415 is worth buying? If what i've heard is right, Tamiya is releasing a new TRF415 kit with the new schock towers and new suspension. Please correct me if i'm wrong thanks.
#4215
Originally posted by A-Ko
Coop,
A track owner that I know said the higher the better. He said he had 9s and paid $10 a bearing for his TC3. If you get 5s or 7s they should be great.
How do you like your 415 & Helios...?
Coop,
That is what I have been findin out.
I love the 415, outta the box it is probably the best car I have owned. The Helios is definately a monster that I am still learing about all its features.
Coop
