Old 09-30-2004, 10:27 PM   #4051
JimmyMac's Avatar
I dunno, Masami has never won the TC Worlds before (to my knowledge). I'm pretty sure he wants it real bad! He's been dominating the Japanese races lately. It's gonna be interesting to see this year. Reminds me of Star Wars... the Master... or the Apprentice.....
But I'm still pulling for Mark though...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-30-2004, 10:40 PM   #4052
FW-05RR's Avatar
When is this event taking place? also where is this event taking place
FW-05RR is offline   Reply With Quote
Old 09-30-2004, 10:50 PM   #4053
JimmyMac's Avatar
The IFMAR Worlds is taking place near the end of October in Florida.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-30-2004, 10:51 PM   #4054
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally posted by Proficar403
My bet is on hara, not because of hpi, just because he's hara...
Other than:
ZS-501 DIFF HALVES you will get two sets one for the front and one for the rear. you will use the FRONT parts, these will have the equal spacing for the outer bearings.
ZS-506 DIFF RINGS,
ZS-507 THRUST BALLS AND WASHERS
ZC-507T if you want carbide balls
ZS-508 DIFF SCREW AND LOCK NUT.
cost.. less then $20.00 u.s. (little more with carbide balls)
...what parts are neccessary to complete the front diff. Does the stock tamiya pulley work, or do I need a different one? What about bearings, shims, etc?
well, actually you use the REAR outdrives.. they are the ones that are centered. a few thin 10 mm shims will take up the side slack, as there isnt much.
you will need the Tamiya pulley, and you can use the 414/ta04/415 dif rings.. the Yoke uses the double flats, just like it.use the same 3mm balls, like the std Tamiya diffs. there ya go! insta-diff!
dont forget you will need longer CVD bones.. the 46mm from the Evo IV/LW suspension fit perfectly!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-30-2004, 10:54 PM   #4055
FW-05RR's Avatar
thx
Old 09-30-2004, 11:46 PM   #4056
Turbonium's Avatar
here is a little detail pic of my latest appearance mod... im not sure it was worth it, as you can hardly see it!!!
Wes
Team Novak
Old 09-30-2004, 11:50 PM   #4057
Turbonium's Avatar
here was the pic of the installed diff...
Wes
Team Novak
Old 09-30-2004, 11:51 PM   #4058
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Major bLinG Yo!
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-01-2004, 12:51 AM   #4059
mashimaro's Avatar
bling? huh dunt get it
mashimaro is offline   Reply With Quote
Old 10-01-2004, 02:22 AM   #4060
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Default TB EVO 3 Re-inforced Diff Joints
Quick question. Would the TB EVO 3 re-inforced white outdrives OP#53267 fit the TRF415? If so, would it also need a different set of diff plates similar to the one 's used for the F201 outdrives?
Any response would be appreciated. Planning to replace the black outdrives to the EVO3 one's if it works.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-01-2004, 02:51 AM   #4061
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: TB EVO 3 Re-inforced Diff Joints
Nope.
jeffreylin is offline   Reply With Quote
Old 10-01-2004, 03:21 AM   #4062
Ballsie's Avatar
Aluminum Bones on the front? I take it these are good unless you tend to hit things (like I do)?
I finished my diff last night and will test it tonight, but it fells VERY GOOD.
Ballsie is offline   Reply With Quote
Old 10-01-2004, 03:39 AM   #4063
Yes it fits.. you just have to add 2 or three more shims to it (.3mm)
-Dave
Old 10-01-2004, 04:06 AM   #4064
s2
s2's Avatar
what shims are you guys using to remove slop from the diff mod?
s2 is offline   Reply With Quote
Old 10-01-2004, 04:15 AM   #4065
Ballsie's Avatar
I haven't used any shims, but I've not run the car yet either.
I don't feel that there is anymore slop in the diff mod than there was in the standard one-way.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
