Old 08-30-2007, 12:10 AM   #19201
DRAG_ON's Avatar
Originally Posted by maxepower View Post
The white belts and the white pulleys will actually fit on the MSX, you will just have to adjust the belt tensioner to compensate for the longer pulleys. Yes, racers will tell you that the belt is not the proper one to use with that pulley but it does work. I've used it and it will work!
the original MSX belt will work using wide pitch pulley from MSXX??? i do realise i can set the belt tensioner, but will it be too tight considering the white (wide pitch pulley has 36T)
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 08-30-2007, 11:23 AM   #19202
TryHard's Avatar
Nope, There is plenty of range in the tensior to set the belts to the correct tension. Both the original 3mm black, and the white ones will work.
Obviously the MRE belts are slightly longer (but only by a tooth or two I think), meaning you can have the tensioner set tighter.
However, if you want to run 18t centre pulleys, then you will need new belts, no way round that.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-30-2007, 11:28 AM   #19203
TryHard's Avatar
Right guys, just thought I'd post my setup from the KO GP this past weekend. Didn't do too brilliantly myself (lack of racing recently, driving crap etc), finished 3rd in the C in 27t, but Jon Winter (whoose adjustments are in red on the sheet), TQ'd and won 27t, setting a new track record in the process..... so it's pretty much there
Regards
Ed
EDIT - Spotted a mistake on the sheet. The Rear suspension blocks should be A/E not X/D... opps
Old 08-30-2007, 11:59 AM   #19204
RocketRacer's Avatar
is this setup for outdoors/asphalt Ed?
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 08-30-2007, 01:31 PM   #19205
RC MARKET's Avatar
or new choice 37/16T
use TRF501X 37T pulley use MSX MRE belt & XRAY T2'007 rear belt.
RC MARKET is offline   Reply With Quote
Old 08-30-2007, 04:29 PM   #19206
Question to the people out there using the 501x pulley. What pulley are you using on the front of the car? Is there a 37T pulley that will fit the MRE spool?
DOTMAN is offline   Reply With Quote
Old 08-30-2007, 11:01 PM   #19207
Default Setup
Helllo.
Anyone have a base setup for a large track?
I run a 415msx with foam tire and mamba max 7700.
I have front and pulley one way.
I have too understeer on power in large corner.
federico.sa is offline   Reply With Quote
Old 08-30-2007, 11:09 PM   #19208
DRAG_ON's Avatar
Regards
Ed
thanks for your info, i will still be using 16T pulleys, i will give a try to use original MSX belts and white pulley thanks for your help
Old 08-31-2007, 01:04 AM   #19209
AWK
AWK's Avatar
Anyone know the part number for the air scoop?
AWK is offline   Reply With Quote
Old 08-31-2007, 01:30 AM   #19210
You mean this?
http://shopping.rcmodel.hk/images/pr...ta-3454480.jpg
#3454480
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 08-31-2007, 01:37 AM   #19211
I`m using that normal 36t pulley with spool up front in my MRE. In the middle 501x 18t pulley so IR chance that 2.0 vs 2.25
Old 08-31-2007, 01:49 AM   #19212
TryHard's Avatar
Yup.
Old 08-31-2007, 01:55 AM   #19213
Hey Chris
Have you already count those theeth from 501X belts if they fit to TA05MS if want to change that 18t middle pulley?
Old 08-31-2007, 08:29 AM   #19214
TryHard's Avatar
Regards
Ed
Also, fogotten to mention it was good to meet Eirik at the KO. Didn't do a bad job boss
Old 08-31-2007, 08:36 AM   #19215
HappyHippo's Avatar
Eirik is the best RC drivers in norway, he has 24 national titles and am glad to have him as my friend, he is allways helpful and a good suport at races or when you need a cheering up
HappyHippo is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
