Tamiya TRF415
#4951
It comes with a one way but i don't know of anyone who uses a one way on carpet. Try it.
#4952
Which of the blocks dont come with the kit?
Does soemone have a carpet setup?
#4953
I will have my front diff soon an I want to know which shims I will need for the outdrives...Part number for these will be really appreciated! Thx!
#4954
I posted a carpet foam setup several pages back. It's a good starting point but i am still tweaking it.
#4955
Regarding setups there were a lot on this thread. It depends if youre running foams or rubber tires.
#4956
carl ran his car for the first time last night on carpet. car was dialed. made that loud mouth raul mi2 driver look slow.
#4957
Hey guys. I have finally decided to dump my TC3. I have been driving it since they first came out. I have been torn between the 415 and Mi2 for carpet racing.
Can you clear something up for me? The 415 is more for carpet than the 415MS? I hear that that 415 is discontinued. True? If so, what about parts availability?
TRF415 is not discontinued, and I believe the 415 will be better for carpet than the 415MS. The 415 have a 3.0mm chassis, which is very rigid and from talking to quite a few carpet racers, stiff chassis is a good thing. The 415 also have beefier suspension components than the MS. The MS's suspension is light weight but usually carpet tracks are tight and lay out with strong boards which can be harsh on the car's suspension during a crash or a tap. The 415 suspension is also shared with other existing Tamiya models (TA04 and TB02) so I don't think it will be discontinued anytime soon.
Steve Wang
#4958
Thanks guys!
#4959
HiH
Ed
#4961
marc isn't even sure if he used a 2,5mm chassi or 3mm...
but he had hpi 0degr. rear hubs in his (satoshis) car...
btw, results of the orion speed weekend/germany:
1.simo ahoniemi, corally
2.steen gravesen, tamiya/orion
3.teemu leino, schumacher/orion
4. marc rheinard, tamiya/orion
5.marc fischer, tamiya/orion
6.benni grschel, hpi/lrp
7.ronald vlker, tamiya/orion
8.markus mobers, tamiya/fantom
9.jonas anderson, schumacher/peak
10.jilles groskamp, x-ray/peak
i was really unlucky qualifying only 13th with a bad mistake in a possible top-6-run...damn! but its only for joy.....
#4963
Ok guys got to finally run the 415 on carpet. As Chris R. mentioned above the car was dialed, able to put the car anywhere I wanted it. Gave Raul and his Mi2, who is top dog at Hobby Chamber something to think about. I beleive Raul is starting to see blue.
My carpet set-up: basic 415 kit
> stock 415 arms
> A block in the front
> low friction belts
> Tamiya Purple springs FR / Gray rear, both were long
> 50wt shock oil, stock shock tower settings
> DUAL ONE-WAY Bearings
> Parma Foam Plaid/Purple 28mm.
> ball studs in the bottem holes of the steering knuckles. (only cause the alum ball stud broke in the top hole when I tap the inside of a board.) I'm switching to steel
> Parma Alfa 190 body
That's it. Assemble the rest of the car as instructed.
Since, I finished building the car Saturday, really Raul finished it and raced Saturday night I did not have time to try different set-up. The set-up above was an unbelievable starting point. Fast and easy to drive, a little too much mechnaical grip, but I will work on that.
I will have more to post shortly.
Nice chassis photos, but I'd stick with the stock one.
> stock 415 arms
> low friction belts
> Parma Alfa 190 body
#4964
Rims and Tires.
I used the Parma Plaid/Purple, rubber worked great but I found the rims to be made for the TC3 and American axles and hex pieces.
I'm now looking for rims that are tighter on the axles.
Tamiya measurments:
> hex pieces: 12.00mm
> axles 5mm
Parma measurements:
> hex pieces in the rim: 12.25-12.30mm
> axles hole is drill to accept and 8-32 axle.
Problem:
> rim wobbles on the Tamiya axles until clamped down
> after running noticed that the inside of the rim shows signs of the hex's digging in the rim
Anyone have recommendation on which rims fit the axles tighter
Tamiya measurments:
> hex pieces: 12.00mm
> axles 5mm
Parma measurements:
Problem:
#4965
TRC wheels fit the car lot better, I noticist same thing with Parma foams (and wheels are really flexy). Also Parma wheels are offset little different, and makes my car about 192mm wide.
I think I'll stick with Jaco or TRC, the Parma foams were cheaper, but outer ring on front Plaids were so thin! about only 1/8"! by the time I rounded the edges, the outer ring wasn't even making contact.
dawg, if you're using regular offset rims like TRC, it'll stay under 190mm, assuming you are using aluminum rear hubs and 1/2mm shim. However, can't use the rear sway bar, since it'll rub.
