Like Tree2Likes
Tamiya TRF415
Old 11-17-2004, 11:48 AM
  #4921
Trader Rating: 47 (100%+)
Default Re: Re: Re: Re: trf-415 testing on carpet with foam tires
Originally posted by dawgmeat
Also these tires are 28mm, no wheel spacers used
did you have to go to a lower king pin ball? Could you have gotten away with flattening the top of the ball end to make the wheel fit?
Apex is offline
Old 11-17-2004, 02:17 PM
  #4922
dawgmeat's Avatar
Default Re: Re: Re: Re: Re: trf-415 testing on carpet with foam tires
I used the stock lower king pin and evol 4 top king pin,
dawgmeat is offline
Old 11-17-2004, 03:49 PM
  #4923
Kenshin's Avatar
Default Re: Re: Re: Re: Re: Re: trf-415 testing on carpet with foam tires
What blocks did you use front and rear?
Kenshin is offline
Old 11-17-2004, 04:35 PM
  #4924
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Rick Draper
In antother post it says Marc ran HPI silver springs, his father has confirmed this to someone on there. Rick
They were HPI Silvers
-Dave
JDM_DOHC_SiR is offline
Old 11-17-2004, 06:07 PM
  #4925
rtypec's Avatar
-Dave
Dave, what was the option color for the front...you know, one stiffer? I keep forgetting
rtypec is offline
Old 11-17-2004, 06:12 PM
  #4926
You have a PM Rod!!
Old 11-17-2004, 06:58 PM
  #4927
|8t
|8t's Avatar
Anyone know here a part number for shims that I can put between bearing and the small shaft on the wheel axles to remove the play?
Thx
|8t is offline
Old 11-17-2004, 09:11 PM
  #4928
dawgmeat's Avatar
Default Re: Re: Re: Re: Re: Re: Re: trf-415 testing on carpet with foam tires
Kit set up
dawgmeat is offline
Old 11-17-2004, 11:32 PM
  #4929
Registered User
Pyramid's Avatar
Thx
Not exacly sure about the size, but here are some part number that I know,
TA-53585 3mm Shim Set, 01,02,03(x10)
TA-53586 4mm Shim Set, 01,02,03(x10)
TA-53588 10mm Shim Set, 3 types
Pyramid is offline
Old 11-18-2004, 07:08 AM
  #4930
alan1467's Avatar
Default New rear bulkheads
Have you noticed that the 415MS has new redesigned rear bulkheads!!!!
alan1467 is offline
Old 11-18-2004, 10:34 AM
  #4931
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Finally had a chance last night to sit down and start working on my 415 for this weekend. I must admit that although the quality is typical Tamiya, (top shelf) the need to shim the diff & one-way between the bulkheads and the to shim the axles was very disappointing.
Question: I picked up the Optional Front A block like everyone mention. The Header card says that if you combine it with a certain part number it will decrease the width by 2.6mm and increase steering. Makes sense. But I believe the number on the card is for the A-1 front block?
I see that everyone on the internet is posting set-ups with the optional A-block and the D-1 block. Since the D-1 block in wider it sweeps the front suspension arms back. Perhaps its me but shouldn't the option A-block go with the A-1 block. Please advise.
Carl Giordano is offline
Old 11-18-2004, 11:05 AM
  #4932
Hebiki's Avatar
Trader Rating: 26 (100%+)
D/A blocks gives you toe out which in turn gives you more/aggressive steering.
Hebiki is offline
Old 11-18-2004, 11:06 AM
  #4933
I see said the blind man. Thanks for your help.
Old 11-18-2004, 03:25 PM
  #4934
In the front the D block and D Bridge Block is supposed to be zero toe and then you can adjust the toe in or toe out by changing the configurations.
Using the A Block and A Bridge Block will bring in the overall width of the front in narrower. Thard's excel spreadsheet has the block configurations charted out.
Thard TRF415 Website
After putting on the 2 A Blocks I had to adjust the steering turnbuckles to go back to zero toe as it makes the front have a lot of toe in when the arms and everything go inwards.
The excel sheet seems to indicate zero toe for 2 A Blocks. I don't know exactly.
190mph is offline
Old 11-18-2004, 04:16 PM
  #4935
koabich's Avatar
I would have done this myself but using a lower kingpin messes with the roll center of the car.
I did shave the tops off of the ball cups and so far it has been perfect. I have hit walls hard enough to bend the aluminum turnbuckles but so far I have not had a ball cup pop off because i shaved the top.
If you are using rear sway-bars mounted in the stock location, you WILL need spacers or else the tires will run on the sway bar mounts. Also 28mm foams will rub on the lower shock cup (where the shock end mounts to the A-arm) if the shock is mounted on the outer most hole on the front A-Arms (during turns) without spacers
I run 28MM jaco tires all around and i do not narrow them.
I use 1.5mm of spacers on each wheel. this is all that is needed to prevent rubbing, with the exception of trimming a little off of the ball cup. An a stock car the 1.5 mm worth of spacers will make the car wider than 190mm however. If you are worried about being race legal, in the front use the A/D or the A/C block combo and you will be between 188mm and 189mm.
koabich is offline
