Tamiya TRF415
#4187
I guess I will just have to research it myself.
Coop
Coop
#4188
Is the bearings for the shaft the same size as the bearings on the input cups on the EVOIV. If so that kit should work for the lightweight suspension. It would make ense they are about the same size.
#4189
i remember back from my misty boarding past that the higher the abec rating the 'better' the bearing, im 100% sure of that
anyway..
has anyone tried a 415 with a front and rear diff? will i need to make any obvious general setup changes to my usual 1way setup?
cheers
stew
anyway..
cheers
stew
#4190
here's a picture of my car
#4191
Well I finally broke down and bought a Yokomo diff for my 415. Now I just gotta build it.. We'll see in 2 weeks.. hehe
#4192
#4193
Coop
Coop
A track owner that I know said the higher the better. He said he had 9s and paid $10 a bearing for his TC3. If you get 5s or 7s they should be great.
How do you like your 415 & Helios...?
Jeff
#4194
#4195
Has anyone here got a decent setup to start from for don valley on hpi b15-40'S? Im racing at the HPI junior nationals this weekend and have no idea where to start.
Cheers Phil C.
Ps. Im using the standard suspension.
Cheers Phil C.
#4196
Front Arm Toe-in
Hi, I know this was discussed tons of pages back, I just need to recall the specific arms blocks or hinge pin holders in front to make the arms toe-in. What is the letter of the block. thank you for your time.
#4197
Re: Front Arm Toe-in
#4198
Front belt tensioner
I just got this and boy it is tiny. LOL. I hope it works as described.
#4199
it does it works great
#4200
BTW,,,,is it possible to put the TRF sticker on my MY02Monster Jeff ??
