Tamiya TRF415
The 2007 MRE is supposed to come with a front spool and rear diff. Look here under "About the Model":
http://www.tamiyausa.com/product/ite...oduct-id=42104
I've heard that the 2007 MRE model is going to be the final TRF415.
Rear Upper Brace Separate type (new design)
Front Unit Direct drive
Center Pulley 16T
Rear Unit Direct drive
Diff. Pulley 36T
Front AND rear Direct Drive Units (Spool) would essentially make this a drifter....??
Hey double quatro. I read the same thing. Make one wonder. Maybe they will place the new 16 ball diff that marc was running at Reedy.
It clearly says in "About the model":
Race-spec direct drive system equipped with rear ball differential for quick acceleration.
xanavi: i'm paying them with my credit card since we donot have PayPal in the Philippines i have to send them a photocopy of my card ( front & back) plus a photocopy 2 ID ( drivers license & PRC ID) hopefully i will not be paying any taxes since the items are below US $100, they will be sending the items via EMS
I didn't not read any lines that says that this is going to be its last 415 but I am pretty sure that this is definitely the last 415 this year for in the coming of 2008, they will produce the 416 already... The reason why they made the trf415msxx mre is that for the racers out there wont get bored of waiting for the 416... Because it is already in the plan of team tamiya to build the 416 in 2008...
hi
can you tell me when will be aviable the msxx mre
thanks!
thanks!
Coming soon mean September or October?
To answer my own question, I run a front one-way and had to change the front swing shafts from 46mm to 42 mm when I changed to the short suspension arms. Otherwise the swing shaft pushed too hard into the front one-way cup and the front wheels weren't as free as they should have been. I didn't have to change the rear swing shafts, though.
just to clarify.....if you have "A/A" blocks..and run the regular suspension.. then go to the "short" arms... you need to use D/D suspension blocks
there is a 1.0x mm difference in width between an A bridge block and D bridge block.
short arms are 1mm shorter than the regular suspension.
xanavi: sorry do not know the reason why our country has no PayPal account just be sure that when ordering on-line the store should have a very good reputation for customer service and satisfaction then yor card is safe to use with these online stores online stores charged you in US dollars then your card company will convert it to pesos
I'm pretty sure the 'rear direct' means no center one-way, a direct pulley setup, after Japanese to english conversion
