TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#6916
#6917
#6918
Where is the best place to Mount this esc on the mid motor car? I am running a standard servo and a shorty pack. Track I run is med bite. The car has the rocket rc brass anti squat Shim and I have the brass mid motor weight kit can add. Should I run both? Thanks for the help......
#6919
#6920
Tekin rs or a Lrp sxx to to spec
#6922
ok, I'll see what I can do. should I run the mid motor brass kit with the rocket rc antisquat shim?
#6923
slipper seems good , 24 mm ride height front and rear , diff is about 3/4 to 1 revolution of the tire using the flick method .
Also try limiting your front shocks (internally or by raising the spindle)
I recently added some more anti squat and it helped on-power rotation A LOT!
#6924
Okay, so I was told by someone not to run the 50g weight in the rear for MM.
That leaves only my brass weight in my side pods (18g). But... I was looking at caspers setup and he runs the v-1 bulkhead (20g), brass anti-squat (36g), and side pods (12g), which totals 68grams added weight. That is a ton of weight for mod!
Where I was sitting, I have the tlr aluminum caster/bulkhead (don't know weight), the rear brass weight (50g) and a side pod weight (18g), which totals 68g for my ride, which is exactly what casper would be running, except he has shorty packs and I still have saddles.
Now my question is whether all this weight will really do me any good and do I have they weight distributed throughout the car properly?
#6926
#6927
Frank, when running the rocket rc anti squat plate, its not recommened to run the mid motor brass weight kit? Just trying to get my setup sorta close. I have the anti squat plate installed and have the mid motor weight system, and rear motor brass plates in the pit box.
Where would you mount the esc on a med bite track?
I have my 2.0 rear motor dialed in!! So I picked up a mid motor 2.0, I wanna see what it can do.
#6928
#6929
#6930
Hacker, where are they mounting the esc? in front of the battery or on top towards the back?
