TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 03-05-2014, 10:09 AM
  #6766
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Durocken
I wanna try the 20* kick up shim from the stock 25* shim. Any thoughts on what I might experience from doing this? I run on a VERY tight med traction track.
Decreasing caster will generally add some turn..but you will lose some on power steering and straight line stability. .given your track discription this would help on tight off power corners.
Oasis is offline
Old 03-05-2014, 10:23 AM
  #6767
Carranza76's Avatar
Wanted to review this for anyone running stock 17.5 class.
Awesome! I know most guys in my area run a locked slipper or close. I gave this a shot and its on point. now more having to mess with the slipper at all. If i need a slipper its a 2 min change out at most.
Again I only run 17.5 stock glass not sure about 13.5 class using this or not.
Its made for the B4/B5 but it fit directly on to the 22 with no mods. Just need a 1/16" hex driver for the screws.
http://www.exotekracing.com/b5-b4-t4...spur-gear-hub/
Carranza76 is offline
Old 03-05-2014, 11:13 AM
  #6768
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Are you going to change the caster blocks so the overall caster isn't affected?
If you don't, you'll be changing two things: kick angle and caster.
I've found less kick to make the fore-aft weight transfer to happen quicker, sometimes too abruptly.
When reducing Caster, you'll generally have a little more turn in and exit steering, but less of a mid corner rotation.
Frank Root is offline
Old 03-05-2014, 11:16 AM
  #6769
Davidka's Avatar
Trader Rating: 86 (100%+)
A key difference (among many) between the AE B4 and the Losi XXX -
B4 = 20* of kick
XXX = 30*
Those two cars were known for razor sharp steering and solid stability respectively.
Davidka is offline
Old 03-05-2014, 11:20 AM
  #6770
Oasis's Avatar
Are you suggesting to not use the 20 degree shim ? I know you guys spend countless hours testing so most of the time I keep my caster settings stock..
Oasis is offline
Old 03-05-2014, 11:39 AM
  #6771
MartinSorlie's Avatar
http://www.wheelspinmodels.co.uk/i/213701/
MartinSorlie is offline
Old 03-05-2014, 12:11 PM
  #6772
Carranza76's Avatar
Originally Posted by MartinSorlie
So when does this come out in the US?
Old 03-05-2014, 12:14 PM
  #6773
TLRacing
Frank Root's Avatar
I prefer 25*, but you can run whichever suits the driving style best.
Old 03-05-2014, 12:16 PM
  #6774
TLRacing
Frank Root's Avatar
It's not out in the UK. Not sure how they got that photo. The item/parts/pricing are all likely to change.
Old 03-05-2014, 12:17 PM
  #6775
Carranza76's Avatar
So now that its been confirmed can you at least give us some ear candy as to when we might be able to expect it? LOL
I dont mind waiting for it. but you know the questions are going to start coming.
Old 03-05-2014, 12:20 PM
  #6776
TLRacing
Frank Root's Avatar
Nothing is finalized, so I do not have any information other than, there isn't any information to share.
Old 03-05-2014, 12:25 PM
  #6777
Carranza76's Avatar
Fair enough man.
Hopefully you guys can get that worked out soon though!
Old 03-05-2014, 12:43 PM
  #6778
JourneyMan's Avatar
Trader Rating: 91 (100%+)
What is the correct part number for trailing spindles that fit the 2.0?
I see there is a 2MM aluminum for the 2.0, I am looking for the correct part number for the 4mm in aluminum or plastic (cheaper). I don't believe the 4mm listed on amain will fit (TLR1075) although it shows it's for the 2.0.
JourneyMan is offline
Old 03-05-2014, 01:17 PM
  #6779
MasiisaM's Avatar
Looks like the export department at HH jumped the gun. TLR231027 is posted quite a bit in the EU.
MasiisaM is offline
Old 03-05-2014, 01:25 PM
  #6780
TLRacing
Frank Root's Avatar
22 2.0 Spindles stock spindles (w/4mm trail) found here:
http://www.tlracing.com/Products/Def...odID=TLR234007
