TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 06-03-2014, 08:02 AM
  #7666
Mclogo's Avatar
Sorry if I have a question that had already been answered... could not find anything regarding the protective sheet, only the same chassis lenght 22 vs. 22 2.0.
I've just picked up a 22 2.0 and would like to get a protective sheet for the chassis.
Does the "normal" 22 (TLR331000) protective sheet also fit the 22 2.0 chassis?
Thanks!
Mclogo is offline
Old 06-03-2014, 08:05 AM
  #7667
kdeleon's Avatar
Thanks!
Yes, I used the ones that I had from my 22 1.0 and they worked on my 2.0 with no issues.
kdeleon is offline
Old 06-03-2014, 08:53 AM
  #7668
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Thanks!
Yes, they have actually been updated to have the 22 2.0 logo on them now
Frank Root is offline
Old 06-03-2014, 03:52 PM
  #7669
Mclogo's Avatar
Thanks a lot both!
Mclogo is offline
Old 06-04-2014, 07:10 AM
  #7670
Originally Posted by AFK66
Would there be a huge benefit running a smaller spur mid motor to push the motor closer to the rear of the car? Would this give a little more rear traction? A friend of mine has done the opposite on his rear motor configuration to take away some of the pendulum effect in turns and seems to be working well with that setup. Was curious if there would be some benefit in the mid motor config as well.
bravo, we have a thinker on here. I don't know how big the benefit would be. But, I do the same in RM. Also, for RM you should look at motor weight. I run killshots because their 18 grams lighter than almost all of the other motors. and it helps reduce the pendulum effect. As far as MM. I think tlr is working on a new MM rear end seeing how I know of some TLR workers are selling their MM cars
135mikefox is offline
Old 06-04-2014, 07:15 AM
  #7671
AFK66's Avatar
Thanks for the response, I was curious couldn't find much on here about it, changing to a lighter motor makes a lot of sense too.
AFK66 is offline
Old 06-04-2014, 09:43 AM
  #7672
Davidka's Avatar
Trader Rating: 86 (100%+)
There could be a benefit however the 22's motor is positioned well forward of the location of most mid-cars to clear the suspension pivot. That component may be in the way of maximizing the benefit of this adjustment.
Davidka is offline
Old 06-05-2014, 09:14 AM
  #7673
goehm's Avatar
Trader Rating: 45 (100%+)
New Silencer body - looks pretty good. I have to admit, I almost choked on my lunch when I saw the color scheme (I thought Maifield was running a 22 - lol):
http://www.liverc.com/news/new_produ...encer%22_body/
goehm is offline
Old 06-05-2014, 01:43 PM
  #7674
When is the Silencer going to be available?
Dale.0 is offline
Old 06-05-2014, 02:39 PM
  #7675
theproffesor's Avatar
Trader Rating: 66 (100%+)
Looks good, Id like to see it on a rear motor car if it will fit
theproffesor is offline
Old 06-05-2014, 07:22 PM
  #7676
J@UNE's Avatar
It looks good!
The wheels seem to have a thin beed a la EVO, I guess new wheels are ready to be released as well.
J@UNE is offline
Old 06-06-2014, 03:49 PM
  #7677
Changed rear tires to Hybrids Blue compound and have way to many on-power traction. Running mostly Frank Root's setup. So I'm going back to 20 degrees kickup because I liked how it felt and maybe try again 2 degrees anti-squat, currently at 1 degree because track is very bumpy. Question about tire and rims, should I glue the tire to the bottom of the rim bead or bead and lip?
30Tooth is offline
Old 06-06-2014, 04:19 PM
  #7678
ThePanda's Avatar
Trader Rating: 68 (100%+)
Glue down in the trough of the bead. And on the sides of the little valley.
Also... Look into the new evo and proline ⅛ style buggy rims, gluing much easier.
ThePanda is offline
Old 06-06-2014, 05:41 PM
  #7679
could someone email me a setup for a very low bite track? 17.5 or 13.5 motor
[email protected]
tj towne is offline
Old 06-07-2014, 05:06 AM
  #7680
Thanks, only glued the bottom of the trough like BK did in Basildon '93 to see if it was less affected by ruts and holes. I don't think it made a difference but I'll test more next week.
I'll look into those EVO wheels, looks like it will be way easier to glue correctly.
30Tooth is offline
