TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 08-26-2014, 08:55 AM
  #8416
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by joss9999
hello , I am new to rc with a 22.2 that i run in France on astro (verry hight grip when dry , none when wet) . I would like to know if it is good to raise the gear box 1mm like with the 22.1 .
thank you in advance.
It has the same effect, but we don't generally feel like we need it with the 2.0 like we did with the 1.0.
Frank Root is offline
Old 08-26-2014, 09:29 AM
  #8417
Default Phend Wins 2wdMod National Title!
The kid is amazing... Fastest man alive.
http://2wdmod.com/2014/08/26/the-phe...onal-champion/
sir_thomas is offline
Old 08-26-2014, 09:43 AM
  #8418
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yep he just reinforced that it was not a fluke last year. He was really fast. RM looked to be struggling all weekend, but Phend was on top of it all weekend long. He had a real shot at 4x4 buggy also, but a couple mistakes cost him.
Wildcat1971 is offline
Old 08-26-2014, 09:46 AM
  #8419
TLRacing
Frank Root's Avatar
Not sure your description of struggling is accurate - Maifield qualified 3rd and finished 2nd overall...
Old 08-26-2014, 11:00 AM
  #8420
Casper's Avatar
Trader Rating: 34 (100%+)
Raising the tranny is not common on the 2.0. A feature of the 2.0 I would suggest playing with however is adding the axle spacer for high bite astro but if traction is low I would remove the axel spacer. This is the 1mm spacer between the inner bearing and the CV joint referenced in the assembly manual.
Raising the tranny on the 1.0 was to increase rear traction on exit. I would think for astro you would be looking to free up the car so not sure this is a change for you to even play with.
Casper is offline
Old 08-26-2014, 12:12 PM
  #8421
gticlay's Avatar
Trader Rating: 14 (100%+)
I have noticed the 1mm axle spacer info missing from the newer setups - like on the Maifield one. Unless I just keep missing it.
gticlay is offline
Old 08-26-2014, 12:29 PM
  #8422
TLRacing
Frank Root's Avatar
Ryan isn't running the shim.
Old 08-26-2014, 02:34 PM
  #8423
gticlay's Avatar
OK, thanks. I humbly suggest a checkbox on the setup sheet for it.
gticlay is offline
Old 08-26-2014, 03:09 PM
  #8424
Thaks for the quick anser.
I do have one more question , I noticed that pheng and rm are not using the rear weights but use weights in the midle , is it to have beter balance car for corner speed?
joss9999 is offline
Old 08-27-2014, 07:28 AM
  #8425
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
XXXDad is offline
Old 08-27-2014, 07:32 AM
  #8426
Glenn those are good for at least a 1/10th
Old 08-27-2014, 08:42 AM
  #8427
kdeleon's Avatar
Originally Posted by XXXDad
Nice, can you provide more details? I would also like to do the change. I assume you dremel the current wing mounts. But then what size drill bit did you use and what size screw.
kdeleon is offline
Old 08-27-2014, 11:53 AM
  #8428
HollywoodRC's Avatar
Default Wing Mount
You can also use one of these.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-wingmnt.jpg
HollywoodRC is offline
Old 08-27-2014, 12:45 PM
  #8429
Wish they made one for rear motor.
potatobed409 is offline
Old 08-27-2014, 01:30 PM
  #8430
Jerm13's Avatar
Trader Rating: 36 (100%+)
I would prefer to use both, not just one.
Who makes those??
Jerm13 is offline
