![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Well, I have never run any other after market chassis other than the BUMP, but I have to say it is a nice improvement over the stock one all around. I have been running mine at Mike's Hobby shop in Porter, TX and she is nice and level in the air over their huge triple. Right now I run the TLR chassis brace in the rear but I may switch to the stock one. Anyways, one more +1 for the BUMP, not to mention, you can get the TLR kit and Bump chassis from nitrohouse.com for $189... Can't go wrong there.
This is the best chassis I've ever owned its better than all other versions (opinion).
The holes don't line up properly and I had to drill it out just to make it fit (fact).
See this is easy
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
That said, as a avid researcher of RC products and upgrades I love as many opinions and experiences to be posted on any given product as I can find. These opinions and experiences you are complaining about are posted in the correct forum and in the correct thread and if you don't agree with them you have the right to disagree, post your personal experience or opinion as well.
The thread, the hobby and certainly the world isn't coming to an end because of this
Sorry my 2c
Im running a RX8 esc with a Tekin SCX4 4.5 and my system seems to be getting a litle to hot after 5 minuted or so and my battery is only lasting about 5 minutes. My drive line is smooth with no binding and the only thing I can think off is the RX8 I bought used on here is set up to strong. Any suggestions on a set up for my RX8 when my programer comes in?
You don't mention which pinion gear you are using. I'd start with a 14T.
As for the RX8, 50% max timing advance, 80% current limiter, everything else is personal preference.
BCE = rabid fanboys..
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
Is the surface a little slick? You're running pretty light oils and I notice that trucks are sliding around the corners. You try that at my track right now and you'd be on your lid.
to me I dont see any difference where the weight is, my truck is probably not even balanced, but still jumps perfect and that. I have better turning with weight in the front thats why i have my battery forward and my diffs at 4,3,2 because 5,3,3 wasnt good enough.
This is the track I usually run at and started 6th and got to 3rd in the s section then was good but as the race was going my motor screw was coming loose and notice a loss of power each lap(the light orange truck): http://www.youtube.com/watch?v=zUN2i...eature=channel
