Like Tree9Likes
Old 03-08-2012, 04:01 PM
  #30796
scracer68's Avatar
Originally Posted by Cult Racing
umm your motor is the problem. The sc4x motors sucked and would always heat up. I've had the 4.5 and the 5.5 and yes I geared correctly.
I have a Tenshock SC411 on order as soon as they come in at Builtrc I'm trying that out.
scracer68 is offline
Old 03-08-2012, 04:05 PM
  #30797
scracer68's Avatar
Originally Posted by ChrisAttebery
You don't mention which pinion gear you are using. I'd start with a 14T.
As for the RX8, 50% max timing advance, 80% current limiter, everything else is personal preference.
Thanks for your help Chris. I'm running a 16 tooth now, I'll gear down to a 14 and set my RX8 like you suggested.
Old 03-08-2012, 04:19 PM
  #30798
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by KingHobbies
King Headz just released two rear chassis braces, stock length and extended.
Also check out the Center Diff Front Upright.
So the front diff outdrive is bearing suppoerted... very nice!
symmetricon is offline
Old 03-08-2012, 04:20 PM
  #30799
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Is the surface a little slick? You're running pretty light oils and I notice that trucks are sliding around the corners. You try that at my track right now and you'd be on your lid.
Its a little slick when they water it, but after a heat or two it drys up. its almost like WCRC if you ever been their.
Cult Racing is offline
Old 03-08-2012, 04:38 PM
  #30800
Sure looks like it supports it. I'm sure it would negate some of the outdrive wobble but I wonder how well the bearing will hold up. Might work on other chassis also.
Jedev is offline
Old 03-08-2012, 05:09 PM
  #30801
larlev's Avatar
Bearing shouldn't be an issue at all...if anything will be a benefit
larlev is offline
Old 03-08-2012, 05:12 PM
  #30802
Exactly
Old 03-08-2012, 05:15 PM
  #30803
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Sorry for the noob question here, what would be the difference between the two braces (short vs. extended)?? And that center diff looks tempting, if it helps to eliminate wobble I'm all for it.........
ilanstylz is offline
Old 03-08-2012, 05:16 PM
  #30804
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
I just got my rx8 and pro 4 4600 was wondering if I can loosen the screws on the front of the motor aand rotate it to get the top of the motor to sit straight up and down? Also can someone post a pic of how they have there rx8 sitting in the truck and so I can get an idea on how to keep the wiring clean? Are you guys eliminating the switch on your rx8's?
Gas Rat Racin is offline
Old 03-08-2012, 05:21 PM
  #30805
search the thread for rx8 clean wiring and you should find a couple posts with pics. i left my switch. i like having a switch, but if it malfunctions i will remove it.
skyler hays is offline
Old 03-08-2012, 05:26 PM
  #30806
larlev's Avatar
It's just a flex deal...less or more. You could say some twist would be taken out also with longer brace. These trucks need some flex, much better handling than all stiffened up.
larlev is offline
Old 03-08-2012, 05:37 PM
  #30807
Default setup help
i am running dustin evans setup. 3-3-2, 30 wt oil #3piston black spring and #5 pistion and 30 wt oil in rear and silver spring. rx8 and 4600. i am not happy with the way the truck handles thru our tracks tight infield sections. i have to hit the brakes to make the truck rotate thru 180 turns. i would prefer to not have to use the brakes to make the truck rotate thru the turns. i would rather brake before the turn, make the turn then accelerate.
i drove my friends truck. 553 30wt all around with stock pistons and springs(rx8 4600 also). his truck rotated so much better than mine. i am confused because in thoery 332 should off power steer better than 553, but it doesnt atleast for me. maybe i am confusing off power/on power steering. after driving his truck i moved my shocks to the same positions as his and it helped but im still not satisfied.
im gonna go 553 or maybe 753. will 753 make the truck rotate better or worse than 553?? sorry to be so long winded. but im tired of changing diff fluids!!
Old 03-08-2012, 06:12 PM
  #30808
Dano628's Avatar
Never had a problem with my 4.5 works great never had temp issues . But then there you go mine must be magical since they suck .
Dano628 is offline
Old 03-08-2012, 06:45 PM
  #30809
Dietz's Avatar
Try .5 down on the front kickup block, rear hubs forward. 5/5/3
Dietz is offline
Old 03-08-2012, 07:09 PM
  #30810
tc5 man's Avatar
Seems like extra weight to me on the center alum mounts but yea it will help the bearings and the wobble you guys are talking about.
tc5 man is offline
