Like Tree9Likes
Old 03-11-2012, 04:27 AM
  #30931
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by empire39
sorry, yes its the 3800kv with a 14t pinion. batterys were never a problem at 1st started hapening more as it got warmer outside. should i try to re gear? what do you suggest?
I went all of last summer with my 1410 geared 15t outdoors even when temps were in the upper 90+ and high humidity. Granted my truck is lightened a bit, but 14t shouldn't ever get over temp. What temps are you pulling? I wouldn't even worry until you get near 180, really they are suppose to be able to handle up to 200 with out issues. Once you go over 200 for any reason the motor temp will be near impossible to control, and you should replace the rotor (easy 30 fix). Also make sure all timing and settings are at the minimum in your esc as well. You don't need or want timing on a sensorless motor.
8ight-e is offline
Old 03-11-2012, 05:52 AM
  #30932
lewis4x4's Avatar
Originally Posted by Potoczak
Is anybody running the extreme racing carbonfiber chassis for this truck. If so what are your opinions??
+1 - Any thoughts?
lewis4x4 is offline
Old 03-11-2012, 08:11 AM
  #30933
Bigz84's Avatar
Trader Rating: 24 (100%+)
Default bce chassis
Hello, I am new to this truck. I have coverted my truck to the bce chassis and i have put the losi rear torque rod on the truck. are you finding that the torque rod doesn't completely tighten down, or are the set screws supposed to show, about 2mm each side of the rod?
I will be running on a indoor clay surface and when not running there, ill be running on a indoor rubber surface, something like what you would find at a ice rink that protects ice skates blades that you walk across the floor with.
Will it be better to run the stock rear brace at the clay track where traction in not high and run the torque rod at the rubber track where traction is high?
Is the torque rod supposed to take away traction?
Sorry if these type of questions have been asked, i couldn't find such questions asked/answered.
Thanks for any help.
Bigz84 is online now
Old 03-11-2012, 08:39 AM
  #30934
Integra's Avatar
Originally Posted by rifraf
Help needed..I am sure this was covered some pages back, but lots of pages to look through and I am being lazy.lol..I run on a large 1/8 scale offroad track with some long straights, and was wondering which motor would be the fastest with good bottom end also. tekin scx4.5 550 OR Pro4600? Thanks,
4600 and your golden.
TLR brace on Traction , Stock brace with anything but.
Integra is offline
Old 03-11-2012, 08:54 AM
  #30935
Bigz84's Avatar
thanks for the info
Old 03-11-2012, 11:20 AM
  #30936
Starting to be a pattern here. I love this truck. It's so stable and just goes where I want it to.
GPatterson is offline
Old 03-11-2012, 12:54 PM
  #30937
I have not messed with any settings just putit in and went for it. I'm pretty green at all this, if I get the castle link is it pretty easy to figure out? Is the standard setting they come in maybe to much for what I'm runnin?
empire39 is offline
Old 03-11-2012, 02:32 PM
  #30938
Chad Smith's Avatar
Hey guys, I need more on power steering, I am running 5-5-3 for diff oil and the kit setup.
Chad Smith is offline
Old 03-11-2012, 02:53 PM
  #30939
What are some ways i can free up the rear end.Its locked down causing me to push.Im running dunfords setup with beams front and back.Thanks!
Losi57 is offline
Old 03-11-2012, 03:22 PM
  #30940
anyone know which size and length screws fit the pro 4600 and the t8 motors? I have my 4600 mounted up, but i want some extras. I think the 4600 and the t8 take the same screws. couldnt find it on tekin's site.
skyler hays is offline
Old 03-11-2012, 03:58 PM
  #30941
Default Diff fluid tuning
Ok im currently running 5-5-3 and am looking to get a little more on power turning, on throttle it wants to push. I am thinking at going 7-5-3. Im running on a indoor clay smooth and grip is pretty good, running pink beams too. Just looking to get some on power turning so will 7-5-3 be better?
rrussell is offline
Old 03-11-2012, 04:08 PM
  #30942
Jake C6R's Avatar
Hi all, I searched through many pages but want to confirm as I am new to the electric world. I just bought the Tekin Pro 4 4600 and the RX8 for the roller and am trying to decide on what pinion for a larger outdoor track - can I start with a 16 or is 15 a better place to start? I'm looking at the roller manual and it says a 16 or 17 is recommended depending on the motor. Thanks!
Jake C6R is offline
Old 03-11-2012, 04:12 PM
  #30943
Cult Racing's Avatar
Trader Rating: 42 (100%+)
If its a large outdoor track, I would say 13, and then work you way up or down from there.
Cult Racing is offline
Old 03-11-2012, 04:30 PM
  #30944
Originally Posted by lewis4x4
+1 - Any thoughts?
What are you wanting to know?
XTREME RACING is offline
Old 03-11-2012, 04:43 PM
  #30945
I ran the 4600 outdoor last summer using a 14 tooth. It was plenty fast even for the largest of tracks. 13 tooth if you you are running a mid size outdoor track or indoor. It has plenty of grunt & top end. I think 15 would be pushing it a bit in terms of heat. I've seen the losi guys discuss pinions & they recommend 13 & 14's for the 4600. Its worked for me too.
JASF4I is offline
