Like Tree9Likes
Old 03-21-2012, 06:11 PM
  #31531
Trader Rating: 128 (100%+)
Originally Posted by RustyRC
Got one w/free screws set.
from?
Neesh is offline
Old 03-21-2012, 06:21 PM
  #31532
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by riverdog
One more question as I work through my rebuild...What should I do to my pro4 to keep it running well? I assume I should use motor cleaner, lube the bearings, and give it a good inspection. Anything else?
youtube has a tekin t8 maintenance video.. use that for visual direction.
Basically take it apart wipe down the end bells, bearings, use a small brush then a air compressor or can and blow the slator and re-assemble (use some thread locker).
While apart inspect and replace the bearings if needed (abec 5 or better). Recommend's from most is to not use motor cleaner or anything that will get into the bearings or on the circuit board or mess w/ the plastics within. They say every few races or weeks clean and inspect, I would say every 4-5 mos if you only run 1-2x weekly.. that or get the motor into some really nasty stuff.
8ight-e is offline
Old 03-21-2012, 07:37 PM
  #31533
cavg's Avatar
Originally Posted by cavg
I did this all around my truck. Felt fantastic afterwards. Went to practice and ran maybe 6-8 packs and after that they do not feel very good at all. I have yet to inspect them further but they don't feel smooth to say the least...
Upon further inspection - they are ok.
cavg is offline
Old 03-21-2012, 07:50 PM
  #31534
krash'um's Avatar
Originally Posted by Neesh
thanks for the quick response! I may bite the bullet on this...still debating if I should wait for the Kingheadz one instead.
Just pull the trigger already and don't look back.
krash'um is offline
Old 03-21-2012, 07:52 PM
  #31535
BmainStar's Avatar
Two guys at my local track run the Jammin. One of them is always in the top 3. I just ordered the BCE because is was available and really shiny.
And the fastest guy at my track used to wheel a Slash 4x4 and whip on on everyone runnin the Jammin truck at that time
When I had my Jammy I would break a front end part every time out!!!He will not get any more of my money that's for sure!!!!!!The chassis debate gets old but it does show the passion that this truck has in the r/c community! And dont forget if you want to talk about the B-- part you gotta take it to P.M.!!:nod :
BmainStar is offline
Old 03-21-2012, 08:21 PM
  #31536
Trader Rating: 30 (100%+)
I just noticed on my SCTE the center diff outdrives seem to have a LOT of play in them. I don't remember my old SCTE being like this. I just got it and its unused, is this normal? The outdrives can be moved up and down,and side to side, they don't have any in to out play if you push and pull on them.
Jay13 is offline
Old 03-21-2012, 08:23 PM
  #31537
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Normal. No big time adverse effects due to this reported as of yet.
SEF is offline
Old 03-21-2012, 08:27 PM
  #31538
How does this truck balance out left to right? I know it depends on the motor and battery but is it pretty close? I was thinking I might go Pro4 3300kv on 3s but don't want to throw the ballance way off with a 540 can on one side and a 3s battery on the other. Any thoughts? I know 3s is not Roar legal but the tracks I run at don't care. I like the efficiency, cooler temps,and longer runtime of 3s but I'm afraid of throwing off the balance.
Jay13 is offline
Old 03-21-2012, 08:29 PM
  #31539
Ok, thanks. I just didn't remember my first truck having this play but I never really paid attention to it either.
Jay13 is offline
Old 03-21-2012, 08:36 PM
  #31540
Registered User
Trader Rating: 25 (100%+)
from?
Main hobbies.
RustyRC is offline
Old 03-21-2012, 09:34 PM
  #31541
10sctrel0v3r's Avatar
buy the kings headz center diff with dual bearings. i just put mine on and it has stopped all play with the outdrive going to the front. upon further inspection of my axles i found one that i had replaced weeks ago from the pin wearing down that i have also cracked it on the end where the pin is. im not sure if this has happened from me adding suspension travel by screwing the shock ends off or not but i know i have a ton of rear travel. i think the suspension may have extended so far that the axle got bound up in the outdrive causing it to crack. i think it created a fulcrum point on the shaft and the edge of the outdrive and instead of bending it, it split. do you all understand what im trying to say? kinda hard to describe without pictures
10sctrel0v3r is offline
Old 03-21-2012, 09:55 PM
  #31542
Originally Posted by HighLife420
Approx how much run time you get out of the 6k? Approx weight?
I was just wondering guys, any way to add a tad more on power steering without changing diff fluids?
My nano 6600 mah battery weighs less than my venom 40c 5000mah battery. Also I charged it last night after a run to lvc & my charger put 6900mah in it. I'm very happy with this battery.
JASF4I is offline
Old 03-21-2012, 10:10 PM
  #31543
shinnbad12's Avatar
Default pro 4 4600
I am switching from the Tekin 4.5 4x4 SC motor to the Pro4 4600 kv and was wondering what all i will need to change in the speed controller if anything? I realize the gearing will be different but didnt know what else. Thanks in advance.
Scott
shinnbad12 is offline
Old 03-21-2012, 11:25 PM
  #31544
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
No you didn't do anything wrong, just a crappy material or a bad line.
Mr.juarez is offline
Old 03-21-2012, 11:38 PM
  #31545
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RC*PHREAK
one thing i noticed with the 22 shock spacers is that there appeared to be three different thicknesses in the bag. i used the middle one. the thinnest one was definitely too thin. the middle one seemed like i was getting some compression on the o-ring when i tightened the collar. i think the thickest might have been too thick.
http://www.amainhobbies.com/product_...ter-Set-TLR-22
The middle one is 1mm, thats the correct limiter to use.
suby723 is offline
