Intergalatic ----> LOL Awesome! "First Annual"
Count me in... Anyone on the bill yet? I'm sure Winn will be the local pro ranked #1 for odds ;P Wonder if this will spark the class and get Tommy and the other pro's in as well.. ouch odds are going down by the second for a podium LOL should be awesome.
Best race facility, and crew in the North East iMO... CRC Raceway in Rome, NY. Come to the pro-series this year, it's always a awesome weekend... that or the GLORC's event. There was talks of a larger short course event this year as well.. but not sure if anything solidified or not.
Great LHS too.. they just started selling the xerun 540 4 poles here, I'll be getting one of these next if I don't like the or mess up my tekin 4600.
I see most pro setups call for the front camber links in the bottom position on the shock tower. Does moving them up give it too much steering or cause the rear to swing around real bad? I never tried them up and am curious if anyone has.
Sir where did you get the L shape plugs at?
Not speaking for him, but I use these plugs with a little dremeling, I guess it works with any 4mm bullet.
Hi there,
Anyone using "counter" droop screws in front (the ones that go in the chassis)?
Seems to reduce droop far too much even with droop screws removed...
The A-Arm eventually hit the flat head of the "counter" droop screw.
Anybody would recommend removing these?
Thanks,
V
Thanks,
V
Hi there,
Thanks,
V
Thanks,
V
A lot of different posts say take em out. I used to run droop screws now I don't. try it save em. you can always put them back
cant wait to try out my new Thunder Power motor tonight...
BCE chassis
Just got the BCE chassis and having a hard time with the center diff. I figured the plastic stock part under the center diff is not needed. But without it I cant get the diff to spin freely. Did you used other screws? Which or how did you installed it???
Rear part went ok, the battery tray gave me some trouble as the holes werent lined perfectly but I managed. Thanx
Lightweight outdrives
In a recent magazine article about the Losi TLR TEN-SCTE tuning kit (TLR0901), it mentioned the kit did not include lightweight outdrives that are a must have option. They supposedly don't wear as fast as the stock units. What is the LOSA or TLR number for these?
TakeAim
TakeAim
TakeAim
TakeAim
