RC10B4.1 FT/WC
Old 03-25-2012 | 07:26 PM
  #13141
1Fastpede's Avatar
all of you 17.5 guys non boosted. is it crucial to run a big 50/60C battery or does the 35c packs work great?
1Fastpede is offline
Old 03-25-2012 | 07:36 PM
  #13142
B.A. Racer's Avatar
j concepts have shown their aluminum bellcranks for the b4 at cactus
B.A. Racer is offline
Old 03-25-2012 | 07:41 PM
  #13143
1Fastpede's Avatar
right after i ordered my avids lol
  #13144
mxracer458's Avatar
I could tell the difference between my 45c peak and my 60c promatch packs
mxracer458 is offline
Old 03-25-2012 | 08:50 PM
  #13145
trickedout's Avatar
hey guys messed up a shock on my new b4.1 worlds and just want to be clear that i need 1.02'' shock shafts part number 6417 and 1.32'' shock bodies part number 7479 correct? I might just go the whole shock kit but still incase, is that correct
trickedout is offline
Old 03-25-2012 | 09:35 PM
  #13146
Part # for blue spacers under ballstuds? i see small dia. ones on knuckle and bigger ones on tower
Seems i am a little late to the party. There are the big bore shocks right there in the picture. Was told today by some team drivers they are about a month or two away and will be sold as an option. A kit with big bores is still a way off. Supposedly the hold up was the availability of springs.
This is Big news for me because the only thing preventing me from a purchase were the shocks. I am told in the meantime to use Losi 22 white and red springs with Traxas collars. Does anyone know the part number for the collars?.
zipperfoot is offline
Old 03-26-2012 | 12:01 AM
  #13147
OptimumRC's Avatar
Only thing that sucks is that you'll still have to modify your shock towers to clear the Big Bores, not necessarily plug-in-play.
I also hope that the shocks have better anodizing colors. The current blue cartridge cap and black collar and cap is hurting. Personally I'd like to see them look more like their touring car and be all hard anodized black with blue shock collar and cartridge cap.
OptimumRC is offline
Old 03-26-2012 | 12:42 AM
  #13148
littlevette's Avatar
TRA3768 Traxxas Shock Spring Retainers (Upper & Lower)
littlevette is offline
Old 03-26-2012 | 01:23 AM
  #13149
whats the part number for those caster blocks ?
ive only ever seen them with two options, not three.
ed
Edwin Pibal is offline
Old 03-26-2012 | 06:22 AM
  #13150
Default Tacon motor
Need help with these motors, i bought 2848 540xl.
for some reason will not fit in my B4.1. when i try to install the gear will not line up with the spur. Its a 16 size gear, Is there a motor size that i should be getting for this buggy? Gonna make an order in a few days.
one4rose is offline
Old 03-26-2012 | 07:57 AM
  #13151
Mxer59's Avatar
Sorry for the dumb question, but what size are the rear turnbuckles
Mxer59 is offline
Old 03-26-2012 | 09:02 AM
  #13152
bilster44's Avatar
You won't have to modify anything to run those shocks...all you have to do is run a longer front upper shock mount screw which would go from a 3/4" to a 7/8", and then put on a 2mm spacer before the bushing and you are done. There are no clearance issues with the rears at all either.
bilster44 is offline
Old 03-26-2012 | 09:26 AM
  #13153
Jake S's Avatar
Originally Posted by bilster44
You won't have to modify anything to run those shocks...all you have to do is run a longer front upper shock mount screw which would go from a 3/4" to a 7/8", and then put on a 2mm spacer before the bushing and you are done..
that sounds like a modification to me, but if you look at maifield and cavs cars they have the tower modified so they dont change the shock angle.
Jake S is offline
Old 03-26-2012 | 10:01 AM
  #13154
OptimumRC's Avatar
Oh, so you have a set?
From what I have seen (including in the pic below of Cavs car), you still have to dremel the front tower to clear the collar and the shock cap on the AE BB's doesn't have as tall of an eyelete as the kyosho ones so in the rear the cap can rub on the tower.
Old 03-26-2012 | 10:15 AM
  #13155
Tdiddy's Avatar
From the B4.1 manual, they are 2". Part number 1406.
Tdiddy is offline
