RC10B4.1 FT/WC
Old 04-19-2012 | 05:09 PM
  #13891
idrummerboy13's Avatar
am i crazy or the finisher makes my car feel much more aggressive? Bulldog calms it down a lot!. right now i am loving bulldog and finisher wing!=]
idrummerboy13 is offline
Old 04-19-2012 | 05:42 PM
  #13892
Can someone direct me to or post a setup For loamy outdoor conditions?
peter_robinson is offline
Old 04-19-2012 | 06:57 PM
  #13893
HareTurtle's Avatar
http://www.petitrc.com/setup/associa...dRC10B4.1.html
there are a lot of set ups here. many are very similar, some the same.
if your loamy track is dry and dusty, try the low traction clay set ups. if it is soft and damp, try the soft dirt medium traction set ups - as a starting point of course
HareTurtle is offline
Old 04-19-2012 | 07:14 PM
  #13894
Rich Panganiban's Avatar
For those of you using the carbon "c" hub towers on the rear hubs, which hole are you using? Middle or outside?
Thanks.
Rich Panganiban is offline
Old 04-19-2012 | 07:25 PM
  #13895
mxracer458's Avatar
Thanks.
I use the middle hole,shaved brace with one washer under the ballstud
mxracer458 is offline
Old 04-19-2012 | 08:54 PM
  #13896
slashracer111's Avatar
I noticed that too. I prefer the finnisher though, since it is a little bit more aggressive.
I'm had to trim my Kyosho springs. I couldn't get 24mm of rear ride hight with them in stock form.
slashracer111 is offline
Old 04-19-2012 | 09:03 PM
  #13897
Default Stock 17.5
Anyone run a 17.5 with added weight? I am trying to get better steering and have been told to add weight but I worry that the 17.5 will have problems pushing the car around.
mhall is offline
Old 04-19-2012 | 10:37 PM
  #13898
Autocratic's Avatar
I just got done with some club racing tonight.
Fresh built Worlds kit with Steve's setup (minus BB shocks and carbon), 17.5 Revtech 12.5mm, 75/33. Green Hybrids, JC Medium foam, kit Proline front tires.
I added the kit rear ballast weight, and 1/4oz weight on each side of the servo in the front triangle pods. Shorty pack 1/2 foam back from servo, slight toe out.
Car had a slight push on-power exit but entry and mid corner steering were great.
17.5 is all about getting the gearing right for where your motor likes to be run at. Find that and you should be fine.
Autocratic is offline
Old 04-20-2012 | 06:05 AM
  #13899
Thanks Autocratic! I will play with my gearing a bit and see what happens.
mhall is offline
Old 04-20-2012 | 07:11 AM
  #13900
Originally Posted by rednck21
you run that with a boosted or non boosted 13.5?
ran it with boost on a Trinity Duo (the original one). Temps were in the 130 range after a ten min race.
Bob Barry is offline
Old 04-20-2012 | 08:46 AM
  #13901
Wild Cherry's Avatar
Tech Legend
T4 chassis
Wild Cherry is offline
Old 04-20-2012 | 11:00 AM
  #13902
bilster44's Avatar
Originally Posted by Wild Cherry
T4 chassis
"Not"
bilster44 is offline
Old 04-20-2012 | 01:50 PM
  #13903
Tech Legend
Originally Posted by bilster44
"Not"
O Way !
Old 04-20-2012 | 02:05 PM
  #13904
kdub's Avatar
To answer a question from last page, the springs come with shrink tubing to indicate color.
Our springs have thicker wire and more coils than the Losi kit springs, so they feel a bit different on the track. I think the thicker wire and more coils soaks up the small bumps better and makes the car feel more connected to the track.
Kurt
kdub is offline
Old 04-20-2012 | 02:16 PM
  #13905
bilster44's Avatar
O Way !
Without SERIOUS grinding modifications to the rear arms and hubs, the T4 chassis is ILLEGAL in the buggy class.
